Guess my age! I mean mileage!!
you still got like a week!
same boat, i'm paddling like mad. car is mostly together, but need to find a driveshaft shop, currently.
likely just wind up there selling in the swap
Just an update! Got my heads back from the machine shop ready to bolt on. I was thinking of installing the 5.9 with out the cylinder heads into the car, so it would be easier to get the bolts on the back on the engine, and less of a chance of messing up my long tube headers?
Also I have exactly 30 Days to finish the motor, pull my engine that’s already in the car , and install this 5.9 30 days because my local drag strip will be closing for good on dec 5 for the street car Thursday night 1/8.....
Get er done! And let me know when you go to Irwindale. We’ve been trying to go to as many events there as we can because the end is near. This Saturday we’ll be there for the last Nitro Revival.
Has anyone ever heard of Magnum heads dropping seats?
Most of the factory 5.2 and 5.9 Magnum heads had seats cut right into the head casting itself, so there is no seat insert to drop out. However, there was a few vehicles originally sold to run on compressed natural gas and those heads supposedly got hardened valve seat inserts installed, so those few could theoretically end up with a dropped seat, although I still never heard of a dropped seat on a Magnum.
Waiting on some pushrods, used my checker got all the slack out at 6.962 adding .050 for preload ending up with 7.015
Finished the motor up runs strong! Gets about 12-13inch of vacuum . It had a little lifter tick but after driving it, it smells to have gone away.
Ran a 8.3 at 82.77MPH in the 1/8. Pretty sure I could have made it into the 7.9 range if I had more time to tune! But of well.
1.876 60ft
5.359 330
8.304 1/8
82.77 MPH
**** I was there and saw you run. Wish I knew that was you.
Did you pick up your plaque?
No I couldn’t, I bought my tech card off someone at the gate, didn’t get their name so I couldn’t get one.
Since they had the names of the ticket purchaser, on the plaque.
Here’s the motor currently, dialing it in seems like it wanted more mechanical timing and less initial. It currently has a 600cfm carb. Since I do have that 2800 stall converter ported heads and long tubes might try a 670 vacuum secondary or 750. Or maybe a 650 double pumper lol.
The last picture is a make shift bracket I made for the passenger motor mount to fit the 5.9 using the stock 1967 273 motor mounts.
