uh oh, not getting old are you?... the car gets quieter which is nice too.
Yeah I'm afraid so. Turn 60 next monthuh oh, not getting old are you?
Thanks Garth, I was thinking of trying that, was just waiting to see if someone brought it up before I tried it.
Got the car up in the air this morning and got that starter swapped out, works great now.
So right now I'm on my third official test drive. Driving to work, which is around 1/2 hour each way and mostly highway.
Love flipping that switch and watching the rpm drop, the car gets quieter which is nice too.
Yeah and that's what I saw the first time was around a 200 rpm dropI believe the lockup should drop the rpm a few hundred?
know what you mean, i'm only two years behind youYeah I'm afraid so. Turn 60 next month
Success!!!Just a little update: Since I got the swap done (basically done) a couple months ago I've hardly had a chance to drive it. Seems its been snowing like every 2 or 3 days for the last two months.
Anyway, I'd been having a problem with the lockup, basically not locking up. It worked once, on my first test drive and then never worked again. Didn't figure my brand new switch was bad, but tested it anyway, switch is good. So I figured maybe I had a bad solenoid for the lockup, overdrive was working fine.
So I got online and bought a new solenoid pack, and finally got it in today and got everything buttoned back up.
Went for a nice 40 minute drive (with snow falling again, but not sticking yet), and lockup is now working !
Success !
Also on my first test drives my speedo wasn't working, but got that sorted out.
So on the way home with the overdrive on I can do 70mph at 2500rpm.
I like it !
Well, tried to drop my driveshaft off today. Sign on the door, closed through thursday. So Guess I'll have to wait till friday on that.
Couldn't leave the crossmember bare metal, so threw a little paint on it. Paint is good cause that means I'm done messing with the crossmember.
How did you decide where, or how high, to weld the mount plate to the cross member? (The piece that the trans mount bolts to)
I know you were not asking me, but I used an empty trans case to mock in place. I had to trim a little more (where the red is), not wider but what was already cut. Pretty much just the part that touches the floorboard stays.
Thanks. But I am CLEAR on where to cut. However the US CarTool cross member comes with another piece that is supposed to get welded to the cross member itself. That piece holds the rubber mount.
My question is how do you determine where on the cross member so you weld it. @MileHighDart ?
My bad, it wasn't clear to me til I read this response. Every car is just a hair different, especially being that we are modifying the crossmember ourselves. Ssome cut out more than others, some are lowered, some have SS springs. So they leave it unwelded for you to set your angle where you want, and tack in place. Check it, re-check it, weld in in place
I made my car level by putting a level on the rockers, then jacked the trans so it was pointed on the rear. I then just used a harbor freight $4.95 angle finder and placed it on the end of the trans. It was 4 degrees down, I adjusted it to five degrees down figuring it was easier to add a spacer to lift up that to re-cut to move down.Right. Should I wait until the Driveshaft is made before welding that tab on? What the beat way to check the angle?
This may not be the ideal way, or correct way, but it worked.
Oh ok. You had the trans bolted to the motor, while you did this?
yes, I had the empty case bolted in the car, to the engine. You can see it in the pictures.
Just seeing this.Oh ok. You had the trans bolted to the motor, while you did this?
DoneMileHighDart clear your inbox
