Scamp Rhonda
I'd like to here that explanation also.None of the headers were the same. Explain that.
Just sayin that you tried multiple headers, none of which fit YOUR car. So seems like it might not be the headers.....And since I last commented on your thread a while back, I helped a buddy install a set of Doug's on a 70 duster with a 318, they cleared everything with not even a ding necessary. So obviously my experience has been different than yours I suppose.None of the headers were the same. Explain that.
Here's a picture of my Patriot headers. They seem to be good quality and finish but the passenger side is angled out quite a bit. So much so that it is hitting the torsion bar. There is no reason for that.My conclusion is, put the Damn header on and modify the rest of the exhaust system. I shouldn't have to but I'm tired of messing with it and need to move on, it's been holding up the show for far too long. I'd like to get the car on the road, I have 99% of the new parts I need to finish the car.
It's disappointing.
Nope I'm doing 10x the work to make headers fit so I can build the car into something I can bomb down old logging roads with.The dakota suspension gives rack and pinion steering, bigger brakes,and a much stronger suspension design.Merely as an added bonus it will free up header space.So, you’re doing 10x the amount of work to make your scamp handle like a truck so you don’t have to dimple some headers? Except you’ll probably have to custom make your headers. Thinking truck headers will bolt right up in your scamp with a Dakota crossmember is beyond wishful thinking.
There’s a dozen people in this thread that posted they had no issues at all with their headers. And one that had a terrible time for a still undetermined reason. Seems like you’re cherry picking the answer you want to hear to justify a decision you’ve already made.
Just curious, have you tried some different motor mounts or anything else related to the engine mounting/positioning? Did you compare dimensions on your mounts to some other type mounts? I think we all have had a challenge with something that seemed to work well with others at some point and time, would be nice to know if there is something besides some bad fabrication tolerances causing your issues
I posted about my problems with Dougs a few months ago. I put TFS heads on and then installed Dougs at the time, mine fit like crap, hit everywhere, raised the motor 1/2" beat them, you name it. These f ing harders are way over blown how good they are. You should not have to beat up a 600.00 header, Never would I recommend these headers. Just buy the cheap ones, it won't hurt so bad when you have to dent them. Dougs need to get there crap together.
All the more reason to buy the cheap ones. If I won't to gamble I go to Vegas, If we are dealing with a header fitting with only a 1/4 difference in some cars then whey buy them in the first place. It was sickening to have to dent these headers. I would just but a cheaper brand at half the money and have money left over to buy a hammer.You should try spending even more money on TTI's and having the same experience, they're not any better.
Like I said at the beginning of this whole mess, these cars have 1/4" production tolerances, and in many cases the clearance to the headers is 1/8" or less. Think about that for a second. One size does not fit all. It's not on TTI or Doug's, they're trying to hit a moving target. Add into the mix the fact that we all use different aftermarket parts and you just get what you get. TTI's fit some cars better than others. Doug's fit some cars better than others. Only way to know which one will fit YOUR car best is to buy a set and try it. The Doug's on my Duster fit great! The TTI shorties I bought to replace them to gain a little more ground clearance didn't fit as well as the Doug's did, even though the shorties should have been an easier fit. Just the way it goes.
It's called production tolerances. Have you ever tried building your own set of headers? You're welding thin wall tube to a relatively thin flange. It doesn't matter what kind of jig you use, there is always some amount of warpage.
There's more variation in some of those headers than I would like to see, and it's possible that Doug's has made changes to their production tolerances and are now sending out headers that have larger dimensional variances than they used to. Not sure. But if you understand the production of a set of headers, you'd understand that they're not going to all be identical no matter what. Profit margin tends to dictate what you accept and when you start tossing stuff in the recycle pile, but none of them are ever identical. The same is true for these cars. A 1/4" of body variation is commonplace. Header clearances on these cars often boil down to less than an 1/8". You see the problem. Adjustment is required.
We've been down that road several times in this thread. His motor mounts are no where near the stock dimensions. But although it's been pointed out many times, he's never posted anything to suggest he's tried anything different.
Sounds like my 74 DusterAt this point, this car just makes me laugh.
Absolutely nothing has gone together without modifying it, nothing. ie, everything about this car is a pain in the ***. Hahahaha
Moa what worked on mine as I had to make some clearance for the drivers side torsion bar was I used a long 1/2 inch extension bar ( socket set) Layed bar across the 3 tubes and gave them a hit it came out well and looked Like it was meant to have the indentation.
