I'm going to wrap the header in the area near the starter....
I just bought some 1200* insulation and wrapped my starter instead. Haven't had any issues since.
When using a Starter Heat Shield wrap, is there an issue with having a "metallic" wrap touching the 2 starter cable terminals?
good news is the header wrap will benefit you in more ways than just heat shielding the starter.
It almost always starts but it's annoying.Damn.....that sucks!
I`ve posted this before, I bought a used set of wrapped ,TTI`2" headrs from a guy in witchta, I rewrapped them w/ intentions of having them hi heat coated afterwards, Wanted to make sure they fit right, and that's been about 8 yrs ago, they haven't shown any rust problems yet.Like your headers rusting away in no time
I wonder if TTI uses a higher quality material then some others do?I`ve posted this before, I bought a used set of wrapped ,TTI`2" headrs from a guy in witchta, I rewrapped them w/ intentions of having them hi heat coated afterwards, Wanted to make sure they fit right, and that's been about 8 yrs ago, they haven't shown any rust problems yet.
I know for a fact , mine get hot enough , every time I start it too !! LOLI've run header wrap many times and found this to be untrue. It may quicken the wear of the header but I've never experienced failure.
I am getting some heat soak in my started I think....
The car cranks over great when cold, but kinda "chugs" the starter when fully warmed up.
The question, I've never used header wrap....how do I secure the end? Bis a$$ hose clamp or ????
Anything else I should know or consider?
Thanks!
Jeff
I suggest wrapping the starter instead to keep the heat away from it. You can even find a good product at your local O'Rielly's Auto Part made by DEI called "Starter Shield" that uses velcro. I wrap it up a couple of times with the excess and use some bailing wire to secure it. Mainly because I don't have any of those fancy SS Straps around. They are certainly a better choice of you have them. But, it needs to be pretty long to get around the whole starter and solenoid assembly.
A normal and very big issue with headers on street cars is a "Heat Soaked" starter. That better you shield it from heat the less chance of you getting stuck.
On the good news side, it isn't permenant. You can sit around and wait for things to cool off then try it again.
FYI: A remote solenoid isn't the answer. Because slow cranking occurrs after the solenoid has already been activated and functional. The "Heat Soak" is the starter motor. Higher heat makes up higher resistence.
I like it so much - I just ordered it from Amazon.....I suggest wrapping the starter instead to keep the heat away from it. You can even find a good product at your local O'Rielly's Auto Part made by DEI called "Starter Shield" that uses velcro. I wrap it up a couple of times with the excess and use some bailing wire to secure it. Mainly because I don't have any of those fancy SS Straps around. They are certainly a better choice of you have them. But, it needs to be pretty long to get around the whole starter and solenoid assembly.
