Wutchyoo want?
Wutchyoo want?
Looking at a 392 HEMI ad for sale on local FB. Sent a couple of questions over about it but haven't heard back from the seller yet.
2 numbers show on the block:
1873729 (Think this is a block number, hard to tell from the photo)
3NE571606
1 number on the heads:
1731528-1
It's all in pieces, includes the block, crank, heads and 2 4 bbl carter carbs with the linkages. No pistons, rings, or caps. Selling for 2000. I think this is a crazy price if it's a legit 392. When looking at a couple of sites to ID them, I saw 3NE55 and 3NE56, and NE57, not 3NE57 so I'm not sure.
The hothemiheads.com site has a ton of info. You can even call and speak directly to Bob Walker. Super nice guy and very knowledgeable. 2K for that engine is probably right on target. If it was a good running engine, you're talkin about more than twice and possible three times more.
So do you think 4-5 grand on top of the purchase price to get it back to where it should be is possible? I’m trying to decide if this is worth the effort. I’m going to stuff this in my 71 Swinger to replace the 360 that’s in there which I’ll sell to offset this build if it makes sense
It's all dependent on the person. If you're really good at budget builds and can do a lot of the work yourself, yes, it's very possible. But if you are going to have to farm a lot of the build work out, then probably not. I did all of the cylinder head work myself minus the milling. I also prepped my own block and assembled the engine myself. The more you can do yourself, the more you can save. I was also in the right place at the right time when buying parts.......or you might say I just waited it out.
I’d probably Have a shop do the line hone, magnaflux the block and go through the heads to clean up whatever was needed their but assemble everything from that point. Unless there’s something extra tricky about these that could give me pause to assemble it
Cap # 1,2 and 5 are from a donor, this went well cause they only needed a line hone. Hard to see, but # 1 used to be a # 4. Don't worry too much about the lac-o-cap thing!
View attachment 1715461323 View attachment 1715461324
Costs can add up, depends on how far U want to get into it. Ten G's adds up fast.View attachment 1715461340
View attachment 1715461337 View attachment 1715461338
lots of good info there, but no explanation of the 3NE57. It’s a ‘57 300C 392.
Early Chrysler Hemi's cost A LOT to build. Even with non-race parts. 392's are even worse. Everything for a 392 costs more, and there are a decent number of things that are unique to the 392 because it has a taller deck than the 331/354's did. Without rockers and valve gear you're not going to build it for less than $5k. Quite honestly, I wouldn't mess with a 392 unless I had $10k to spend on just the build. Seriously, just go over to Hot Heads Research & Racing Early Chrysler Hemi Engine Parts and start pricing out some of the parts you need. Without the valvetrain you've got some money to spend before you even start working on the rebuild costs. Sure, you can build a 392 for less than $10k. But given the parts your missing, even a basic rebuild is gonna be hard to get under $5k.
In addition, you will need a decent amount of custom work to put the 392 in your '71. I've seen it done, but you're going to be on your own for a bunch of parts. You'd be far better off and money ahead building a 440. No, that wouldn't be as cool looking, but resale would probably be better since the 392 isn't an engine that normally goes in a '71 Swinger.
Checked the rest of the casting numbers for you, it seems to be a 1957 392 out of a Chrysler 300. So, dual quad, solid cam, adjustable rocker set up. Best of the best. Heck even the dimpled "Chrysler Firepower" valve covers sell for twice as much as a normal set.
But you're missing almost all the good parts. The solid cam and adjustable rocker set up by themselves are worth as much as the rest of the engine. The heads you have are 1957 392 heads, which are good but not as valued as the '55 354 heads, they have a "555" casting number and are the best for flow.
Honestly, a 392 block, heads, and crankshaft with all that other stuff missing and the rust that's present is not a steal at $2k. It's not a bad price, but it's not a great one either. To return it to original form with just its original rocker gear and cam would cost several thousand dollars. The missing main caps are less of a worry IMHO, guys replace those all the time anyway for the cacklefest and nitro hemi builds, so an original main cap set isn't all that hard to come by. And I know guys in the early hemi crowd that have literally just swapped main caps and run them. Not what I would do, but it's not unusual for an early hemi with swapped main caps to work just fine with just a line hone, not even a full line bore.
Depends on the application. Some of them got adjustable rockers, which are worth a ton. Some didn't. The 4 bolt exhaust manifolds are sought after too, and worth a bunch. The only thing is that some of them got different heads, which are not sought after. The water supply and crossover are different. Not a big deal on most builds.
I have only experience with 426`s , but I`ve heard by a guy that's building a nostalgia dragster that the 331 heads are the best .---??
Sorry, I messed that up. 354’s came out in ‘56. The “555” heads that everyone wants are ‘55 331 heads. But there are a couple castings for the 354’s that are about the same as the 555’s, just different casting numbers. The 392 heads are the ones that aren’t liked, because they added material and a less than great turn at the port because of the added deck height on the 392.
That's actually true. The 54 and up 331 and 354 heads are the best. They are actually more of a true Hemi design. The 392 heads are actually the worst besides the tiny round port 51-53 331 heads. Because of how the intake ports are curved more downward, because the 392 is a tall deck engine and rather than make the intakes different, they extended the intake ports which makes the intake ports on the 392 heads much less desirable. The hot ticket is putting the 392 size valves in the 331 or 354 heads.
