Steve Agrella
We updated them with precision brand which are much thicker and strongerYeah, those are cheap parts store replacements.
Is the alignment set now to the set of second specs in the pictures above? I'm sure it pulls to the right. The caster needs to be much more equal.We updated them with precision brand which are much thicker and stronger
I'll agree on the feathering. I'm splitting hairs I guess. The picture is just old school and looks like a biased tire that just feathered a couple ribs when the toe was off just a little compared to scrubbing the whole tire when toe is off by a large amount while a radial tire will flex the sidewall, when toe is off by a small amount and push the whole tread over and just scrub the edge. Inside when toed out and outside when toed in. Comparatively, camber will wear more of the tire than just the edge. It's a fine line to decipher but the numbers tells the rest of the story.I'm not debating it. Yes it can. Just not as exaggerated, as the tread keeps contact with the road much better. If the toe is out a significant amount, yes it can and will.
No, I don't think you are, really. You're speaking in terms where someone probably has their alignment fairly close.I'll agree on the feathering. I'm splitting hairs I guess. The picture is just old school and looks like a biased tire that just feathered a couple ribs when the toe was off just a little compared to scrubbing the whole tire when toe is off by a large amount while a radial tire will flex the sidewall, when toe is off by a small amount and push the whole tread over and just scrub the edge. Inside when toed out and outside when toed in. Comparatively, camber will wear more of the tire than just the edge. It's a fine line to decipher but the numbers tells the rest of the story.
Okay, but I think your dyslexia has kicked in on the direction of pull.No, I don't think you are, really. You're speaking in terms where someone probably has their alignment fairly close.
I'm speaking in terms as an alignment tech for YEARS seeing idiots completely ignore their alignment and come in with tires so feathered from toe that you can just about cut your hand on the rubber edge. So I think we're talking about two different ends of the same subject. lol
Yeah you're right. It'll pull to the left. For some reason, I thought the least caster was on the right side. LOLOkay, but I think your dyslexia has kicked in on the direction of pull.
It's ugly either way.Yeah you're right. It'll pull to the left. For some reason, I thought the least caster was on the right side. LOL
Very true. How anyone could let it go thinking it'd come close to driving straight is beyond me.It's ugly either way.
Here’s the current specs on the car, one thing I should mention the torsion bar adjusters on the control arms the right dude is bottomed out and the left side is about 1/3 the way in.
The left side the torsion bar is hitting the frame
Also the camber washers were completely rounded out, the guy at the alignment shop seems old school and knows what he’s doing fingers crossed
You would think the tire wear would be on the outside with those toe settings.When you say the torsion bar is hitting the frame, do you mean the bar itself or the adjusting lever on the LCA? If the bar is hitting the frame, you have much bigger problems.
Because you have the QA1 tubular LCA's it is possible to "clock" them incorrectly. Based on the differences in your adjusting bolts, it sounds like one of your LCA's may be installed 1 hex flat off from the other side. If that happens sometimes the adjusting lever can hit the frame.
The guy at the alignment shop is a complete moron. First off, your toe specs are wrong even now. Those degrees of toe indicate that you have ~5/16" of toe. That setting should be 1/16" to 1/8". And even if you have other suspension issues, the toe is almost a completely separate adjustment. There's no reason the toe can't be 100% correct, and instead it's way off.
Second, those eccentric washers may be cheap, but it's your tech that rounded them off. The car didn't do that, even if it's completely out of whack. And that means your tech rounded them off and left them on the car.
I have a 1974 Duster, replaced the k frame with a QA1 and QA1 upper and lower tubular control arms.
I’ve been through two alignments and two sets of tires in 5000 miles, the tires are wearing out on the inside treads, very fast the tires are Cooper Cobras 225-60-15
The car was rechecked too find that the 1st guy that aligned the car rounded out the camber washers so they replaced them, now the car pulls to the left, the camber Is good holding now but they say the Caster is out any advise that I can tell these people to get this car aligned properly would be greatly appreciated
Looks good to me. I just divide degrees by 2 to get a rough estimate of inches.Im calculating 0.112” total toe or little less than 1/8”. Using this online calculator:
Convert Toe Degrees to Inches
Inputs:
225/60/15 = 25.6” diameter,
Current total toe = 0.25 degrees positive,
One wheel toe = 0.125 deg.
PLEASE check my work and inputs.
0.112” total toe in is a little less than 1/8
Everything else is new stock except original torsion barsok so it has QA1 k-frame, QA1 upper arms,QA1 lower arms.. detail what the rest of the suspension is. what torsion bars are in it? were all the ball joints, tie rods, bushings, pitman and idler arms replaced too?
That’s what the working on by splitting the differenceIs the alignment set now to the set of second specs in the pictures above? I'm sure it pulls to the right. The caster needs to be much more equal.
It drove straight as an arrow it don’t pull until the camber washer moved however by that time the tires were already badly worn on the insideVery true. How anyone could let it go thinking it'd come close to driving straight is beyond me.
Yes and it pulls to the leftIs the alignment set now to the set of second specs in the pictures above? I'm sure it pulls to the right. The caster needs to be much more equal.
Are you talking that the torsion bar maybe clocked incorrectly in the upper control armWhen you say the torsion bar is hitting the frame, do you mean the bar itself or the adjusting lever on the LCA? If the bar is hitting the frame, you have much bigger problems.
Inputs:
Yeah but he doesn't have .25° of toe. He has .35° on one side, .32° on the other, and a total toe of .67°. So if you put in .335° (this calculator splits it per wheel)
You get .299" of toe, which is a little less than 5/16". This is the toe setting now, not what it was when it wore the inside of the tires. I bring attention to it because that alignment it totally screwed up, and that's the "fixed" version. This shop is in over it's head.
WOW!!!!!!! The 'Ol Boy up at Fred Cox used toe gauge.. maybe that dude used a tape measure and had "Inch-itus"?Thought I had found one but even he screwed up by setting my toe in to 1"!! At the time I had been learning about front end geometry and what caster and camber did for the car so I started to learn how to do it myself then take the car to have it checked. I dialed in the camber where I wanted it and just guessed on the caster (eyeballed it?? lol), set the toe and did a test drive and it felt good and actually went straight so off to the shop we went. The 'old' guy said things looked good except the toe was off a bit so he set it. The dang thing felt like it wanted to roll over on the way home. I set it back to where it was before going and never looked back. And how does one make a mistake like that on an alignment rack??
