BillGrissom
You started out saying all you changed was the radiator. Then turns out you changed the water pump. Anything else like say the fancy fuel controls? A lean idle can cause overheating. Are you sure the water pump is for LA engines? Magnum engine water pumps will fit but they rotate the other way (driven by back-side of serpentine belt).
