Hemi Swapping a perfectly good 70 Duster
Got a few things knocked out this week. Radiator is in, upper hose in an 06 Charger RT hose. The lower I purchased didn't work. I think a hose with a 45 degree angle will work. They seem to be a fairly common universal hose. I trimmed the heater hoses up and they laid out nice and neat. My AC lines previously went through the fender apron where the heater hoses are, but that isn't going to work. I'll block those holes off and run them behind the bumper. I had a friend help me stab the trans, but I still need to connect everything to it. I also received the quadspark modules from DIY Autotune for the "dumb" stock coils. Installing those will likely be a time consuming task since I plan to mount them behind the dash board. This will likely be the only real wiring change from my previous efi setup.
Banging out the little things with plenty more to go. Manifold should be on for good, so why not take some photos!
Looking great Brutha! Have you tried the Gates heat shrink hose clamps? I used them on my heater hoses for a clean look. I like using them on Rad hose splices too, when I can.
Locking great Brutha! Have you tried the Gates heat shrink hose clamps? I used them on my heater hoses for a clean look. I like using them on Rad hose splices too, when I can.
Thanks! I also hate the appearance of worm drive hose clamps. On the LA engine, I had put heat shrink on them and painted them black to mask the ugly.
I've never used them, but that's what I intend to use on the heater hoses since both ends have a threaded fitting for removal.
I'm going to use t-bolt clamps for the radiator hoses. I just need to be careful tightening those because they will crush the aluminum inlet/outlet on the radiator if overtightened.
I used the Gates 32925 for the heater hoses.. 15/16 - 1-1/16. Th only thing I don't care for is the white printing on them. I suppose I could mask it with something
Grainger was the cheapest place, ironically. I have free shipping with them, so I saved a few bucks
Not much time on the car over the weekend but managed to knock out a few things.
"Cold air intake" adds 25HP, right? This will be painted with Cerakote to match the rest of the black engine parts after I weld my IAC bung and a bracket on it.
PS tank and overflow are painted and I had to make a new steel overflow line to the radiator overflow since this radiator has the cap on the opposite side.
The last two time consuming projects are exhaust and installation of the coil ignitor wiring. Getting close!
Ended up getting the coil drivers installed last night. It wasn't as time consuming as I thought it would be. Taking the seat out helped make work under the dash easier.
For those not knowing or understanding why I needed to install coil drivers, I thought I'd explain it. I was previously running LS style coils. LS coils are considered "smart" coils, meaning they have their own driver inside them. There are 4 wires for each coil. Power, engine block ground, ECU signal ground, and ECU logic signal to fire the coil. The logic signal from the ECU is 5VDC based upon duty cycle.
The Hemi coil is only 2 wires. Just like your old school canister style coil, it has power on one terminal and a switched ground to make it fire. If you're following along, you will remember the ECU puts out 5VDC. That's not going to work with a 2 wire coil. Keyswtched battery power is applied to one side of the coil. The output from the drivers connect to the other terminal. The drivers I installed essentially convert the 5VDC signal to a ground signal with the same varying duty cycle based upon your settings.
Once I got the drivers installed, it was time to power up the engine for the first time and start checking sensors, coils, and injectors. Since I made the wiring harness exactly the same as the small block, I started with the same tune and just started making changes from there. I figured this would be easier than starting from scratch. So far it looks like everything is working as it should. I only made it through checking about half of the things. All of the injectors fire properly and the water temp, MAP, and TPS are reading correctly based on the tuning software dashboard. I need to pull every coil to test each one individually. I did test #1 coil before heading in for the night and the coil drivers appear to work.
Once I get through all the coils, I'll setup the IAC, then confirm all the analog sensors are really correct, which I'm sure they are. After than, I'll crank the engine over to make sure I'm seeing the crank and cam signal. If all that checks out, it will be time to put the fuel pump relay in and make some noise!
I think your fuel table maybe close, but you can see the A/F to confirm before driving if you fire it on jack stands. However, timing needs to backed way down from an LA. My max timing under load above about 5000RPM is 22. It varies based on load. Let me know if you want to discuss before start up.
I knocked 15% fuel out of the whole fuel table since the engine is 15% smaller in displacement. No idea if that has any relevance, but figured it would be a good place to start. For the timing table, I found a few examples online and made some things up based on those tables. It's pretty conservative right now.
I finished checking all the coils and all are correct. Also started messing with the IAC, which in my mind is the biggest PIA out of all the things. I bet I spent more time tuning that thing than the damn fuel tables.
It runs! My gates heat shrink hose clamps didn’t show up so I could run it for very long. I put 2 gallons of coolant in it and it still isn’t even up to the water pump. That was enough for me to run a couple minutes.
That single big throttle body sure makes throttle response snappy. It’s pretty damn loud with open headers too.
For the engine gurus, I put the high pressure spring in the oil pump. It has over 100psi oil pressure when running. Is that bad?
Looking great and clean mate i am a still a long way off here as only at paint stage lol Just collecting all the parts for the swap which is slow given i am in Australia.
Have you hidden your headlight wiring loom or is it not currently installed?
The headlight, horn, and fan wiring is all in the driver side fender well. I attached some P clamps with nuts to the bottoms of the fender bolts to hold the wiring up.
AC and heater hoses are in the passenger side fender well held in the same manner.
@Dantra I wiped the white printing off the gates shrink clamps with lacquer thinner. It came off with zero effort.
O good idea on the P clamps i figured they were ran in there, shame they have no inner guard to protect it all. Love a nice clean bay especially with a swap
I have them wrapped with techflex wire loom to protect them. No issues yet!
My gates hose clamps came in Saturday so I was able to get the heater hoses and power steering suction line completed and get fluids topped off. I ran the car on and off for about an hour until my wife had enough of the open headers. Apparently it was rattling the walls in the house. Hmmm, I didn't notice... I'll get the exhaust back on before I run it again for any length of time. Ultimately the exhaust is the last big thing to get done.
I welded the IAT bung in the intake tube along and a piece of flat bar that I will use to attach a bracket to hold it up. Still need to Cerakote the tube, the rain has been ridiculous here so I couldn't get that done. I'll get some final pics once I get everything tidied up.
One thing that I noticed while running the engine was how much better the engine cooled. Once the radiator fans kicked on, the temperature almost immediately dropped low enough for them to turn off. I don't know if its the more efficient cooling system of the engine, or the double pass radiator. Perhaps its a combination of both. My 408 would just hold temp when idling and not moving, not drop temp! Looks like I'll be good for the 100 degree days in traffic with the AC on.
As I mentioned above, the IAC is a Pain in the *** to get set right. I don't know if its a megasquirt thing or not, but it just sucks. The big part is, there's not feedback on them, so the computer doesn't know what position it is in. There's lots of moving it in and out and unplugging and reinstalling... I did some fiddling with it yesterday without the engine running and I think it should be good now. When I was finally able to get the idle down to 800-900 RPM the cam sounds like it will have a decent lope. If its too much, I'll tone it down with some idle advance settings. All that's required to tone it down is to retard timing when the RPM increases, and advance it when it drops. You can also make a cam sound more aggressive doing the this. None of those advanced settings are active right now.
( sorry, I once again got very wordy :) )
I'm excited for ya, man! I think once you drive it, there will be no looking back. As for the oil pressure, I've heard that the rear main is really the only area that people have concern about.. But nobody has been like "oh my god, my rear main is leaking because I have too much oil pressure". I'm running a Hellcat pump in Hoopty 5.7 and it buries the gauge (80) on a cold start.. Around 60 at hot idle. The Darts 6.4 isn't like that tho.. cold start 60 and 25 at hot idle. Had me a nervous wreck for a few days but I've talked to alot of 6.4 guys and they say that's totally normal for a 6.4.
I've always been a bit intimidated by the megasquirt/terminator setups. Sticking with Mopar/Sublime Harness and OEM ECUs just keeps it really simple for me...but mine aren't track cars either. Just need the basics and the OEM stuff performs well. On the downside, if I want a choppy cam, I have to pay for it to be tuned.. outta my league, plus I would probably drive myself crazy.
I've been driving the Dart, every chance I get.. Just a different car with a Hemi and such a nice highway driver now. They definitely run cooler. Hoop and the Dart both run under 200 on the hottest of Days.. And Hoop has a tiny radiator, all crammed in a confined non breathing space! These Hemis just wanna run.. Hot, Cold, Wet or dry, they just run and run smooth. I'm planning to blo it apart next winter and do a cam/lifter upgrade and probably a 46RH.. I don't want to give up my column shift and bench seat haha
Gonna jump in on the Hot Rod Power Tour next week. Not doing the whole week tho. Plan to drop in with the tour, Thursday morning, as they come outta Louisville to Hebron. Spend the day in Hebron and then on to Indy the next day. Then it's a short drive home from there. My wife didn't want any part of it haha. Even tho we did our share of cruises and racing back when we both had our Magnums.. Hebron is where she ran her first 1/4 mile. So, my daughters boyfriend is going to go with me. Pretty excited for him because he's never been to any kind of event or ever been a part of a caravan.
I'll try some thinner on the gates clamps.. I think what I tried brake cleaner and it didn't work
Man, the Power Tour has always been a bucket list item for me. It passed through the city I live in about 10 years ago but my car was in pieces. I always have hope that it will head back south again. For the last several years, the drive to get to it would be longer than the actual tour. I have a couple friends that long haul it every year, regardless of where it starts.
Power Tour has been a bucket list item for me as well, but even this year's new West event was a long ways from my home. Part of why I want an OD in my car is the idea that maybe I can take the 3 weeks off it would take me to get there, do the tour and drive back. Really want a car that can cruise comfortably for hours on end.
Could always just throw a 2.76 gear in it and roll! Honestly, that's likely what I would do if I were to put that many miles on the car even with the OD. 75mph at 1800RPM, yes please.
Even with my A833OD, a 2.76 is still 2000@75. Not that 2K is a bad RPM to cruise at, there's were I run right now with 3.21's and 65 mph. I could drop even further to a 2.45 and hit 1750@75, but I'm not sure the clutch would last with a starting ratio of 7.57:1.
At the same time, a wide ratio T56 with 3.71 gears and 275/40R18 tires is 1750@75 and 1500@65 and still has a starting ratio of 11.02:1 while an A833OD/2.76 combo is 8.53:1.
With the exception of the catch can and some AC lines (which won't be visible), the engine compartment is pretty much done. I painted the HEMI badging on the coil covers with the same paint that's on the exterior of the car. I was having trouble deciding which color to go with, but a good friend who has a really good eye for design suggested gloss black. Considering he's a graphic designer and he hasn't steered me wrong on other things, I had to listen. He was right again. I'm super happy with the appearance. I've said it many times that I was trying hard to knock the ugly off this thing and I think I accomplished that. Dare I say it looks better than the LA engine???
View attachment 1716258751View attachment 1716258752View attachment 1716258753
I love the look!
