One day soon with hope, I’ll need a head porter for a set.
There was a build (a single one IIRC) of a stroker something here on FABO a few years back that didn't quite perform up to the expectations. It was blamed on the heads though a few important questions (by RAMM) were left unanswered. I am wondering whether they are 'fixed' now or whether they just had a bad start back then with one unfavourable 'result' posted here...
Thanks for posting!
This company is right in my 'backyard' and I didn't even know it.
Go check um out report back if u will how operations look etc ###Thanks for posting!
SorryI don’t believe that is Rod Bloomers business.
BLOOMER PERFORMANCE ENGINEERING LLC :: Michigan (US) :: OpenCorporates
I was talking with someone a few weeks ago about a possible cam purchase....... and he said he plans of using those heads.
He mentioned that they revamped the ports a bit.
Do these start out as an out of the box head that they modify, are they using raw castings that they do all the machining on? Ports, chambers, rocker pedestals, etc?
Any more details on that car?they did more than “ revamp” the ports a bit.
Vic spent a lot of time testing and working on them. Couple years actually, been on and off benches a bunch..valve job testing, yada, yada.
They will be capable of running 9’s on a typical bracket A body stroker deal.
The set that i know of already running go 132 on pump gas in not good air at 3175, and there are several issues yet to be ironed out with that combo that definately is affecting ET.
Green 1974. Averaged 10.20 somethingWhich Drag week car was it?
Color?
Any idea what it ran with the Bigmouths?
Sounds promising
Sounds promising.
Is that a one-off set that were hand ported, or an early production version of the cnc ported head?[/QUOTE
don’t hold me to it but the CNC stuff is all done at BES
Once u own a set and ( BECOME ONE ) with themW2’s get no love at all. So much misguided information out there. Mainly from people that have never run W2’s or even laid hands on them.
I have and will continue to run W2’s. They flat out work and get the job done. Just a regular 9 second 340” W2 engine
Check them out see if they are Mopar friendlyThanks for posting!
