its a 74 duster, weighs 3175. Not sure of much else, honestly.
Footbrakes it, convertor is off a lot, couple other issues.
Its been a tich over 132 in the 1/4. Heads were put on just before dragweek.
True pump gas motor, 2.08 valves in these new heads( they come that way)not sure but i think he runs a roller. 28 tire, 4.10 gear.
I believe the thought is it will run 10 flat with the bugs worked out on pump gas, maybe better in good air. Its only been in drag week air thus far.
Has a grossly missmatched Victor 340 on it that needs worked,or more optimally, a super victor. The intake had been on big mouth heads.
As i mentioned before, these heads should support 9’s pretty easily on a typical bracket stroker. And they obviously( like anything else) would be even faster with some compression.
