Sooooo, there back up and running now?Call them / he responded quickly a few weeks ago
I just laugh when all the W-2 naysayers get on a soapbox. I would bet some have never seen a W-2 head in person.
Everyone is afraid of that voo-doo magic....
Maybe someone could direct the OP to the source for brand new W2’s, that are the best flowing complete cylinder heads he could buy for $3k or less.
Only items cheapThere really not that expensive anymore. Yes! They will cost more but then again, you get more. As always, you gotta pay for higher performance.
Once you have the head, you need valves and a valve job. After that, the springs, retainers and locks should be selected for the cam used, just like any other head you get. The only cost savings to a complete aftermarket head is if your cam can used the springs they come with.
Serious builders of power understand this and often change the springs on the complete head right away anyway.
As soon as I got my CNC ProMaxx heads, I whipped out the spring seat cutter and threw away the springs in favor of a spring better suited for the job. Checked the valve job, reassembled the heads…. BAMM BABY!
Oh sooooooo EZ!
True, they are out of the price range even when they did sell complete heads.Maybe someone could direct the OP to the source for brand new W2’s, that are the best flowing complete cylinder heads he could buy for $3k or less.
Not true in all cases.Only items cheap
Have MADE IN CHINA
on them !!
so what about the bloomer heads.....available again?
I emailed and response was quickDoesn't look like his fakebook page has been updated in two years and the Bloomer Performance website link is broken? Can't seem to find anything online from them more recent than 2019. Does he have a site that I'm not finding?
What are the Highest flowing in CFM mopar small block heads as messured on a flow bench
Im asking about Complete heads, under $3000, no modifications, out of the box
If you buy your heads based on flow numbers you are going to do it wrong. Buy your cylinder heads based on cross-sectional area and valve diameter and not flow.
That's what I'm running, W2s with Norris rockers.I should add I sold a set that ran 9’s with Norris rockers for well under 3000.00 complete
W2s will always be worthy candidatesThat's what I'm running, W2s with Norris rockers.
Indeed they do.W2s will always be worthy candidates
Might be old school but they work.
Solid INFOAny head that flows 260cfm at .450 lift will work well. Especially years ago with cams like Racer Browns .520 lift solid lifter cam that many of the guys ran. Combine that with a stock stoke 340 and a little more compression and a good carb and you were ready to rock and roll. Their issue is after .450 lift they fall FAST but that is easily quickly fixed to get 300-305cfm with a 2.02 valve. Up the valve size to 2.05 or 2.08 and 220-230cfm is reachable.
Mopar guys hate offset rockers for some reason. Good rockers are usually at most a one time expense if you get Harland Sharps or T&D rockers. I got a bad taste in my mouth when mine cracked (econo heads) and by that time I could get W2 performance out of a much lighter aluminum head. W2 rockers do need ported to really see their magic.
Amen - the latest Bling is very appealing to many # and all are on a Different path !It seems a lot of Mopar guys hate anything that doesn't look stock, or parts that won't work with their factory parts. For a large part we are our own worst enemy when it comes to aftermarket support.
