Highland Park Hummingbird
Small Block Mopar Engine
  1. I8NEMO
    I8NEMO FABO Gold Member FABO Gold Member
    313
    327
    Jul 3, 2019
    Phoenix, AZ
    Local Time:
    5:52 PM
    Well, I'm installing the Dougs Headers in my 68 Notch 4spd 340 car, and im guessing a mini starter will be added to the list of changes. I was really looking fwd to listening to the classic Mopar starter aka Highland Park Hummingbird once again but that's Hot Rodding. What mini starters do you guys like?
  2. toolmanmike
    toolmanmike FABO MODERATOR Staff Member FABO Gold Member
    52,758
    38261
    Jan 18, 2006
    Iowa
    Local Time:
    7:52 PM
    I got one for a 96 V6 Dakota. It has worked great for 10 years so far.
    • Agree Agree x 2
    • Thanks! Thanks! x 1
    • RammerJammer75
      RammerJammer75 Well-Known Member
      450
      577
      Aug 28, 2020
      Kingsport, TN
      Local Time:
      8:52 PM
      I use one off of a '98 Dakota with a 5.2 and it has been going for several years. Just a carquest brand "new" starter.
      • Agree Agree x 1
      • CRUZE 418
        CRUZE 418 FABO Gold Member FABO Gold Member
        273
        89
        Mar 11, 2019
        Illinois
        Local Time:
        7:52 PM
        I am guessing at this, you did not say why you had to change starters, I miss my gear reduction whine too. So it's a clearance problem, right? My tti's wanted a custom z-bar , then that got into the way of a Dakota starter. Not sure on your Doug's. You can cut, bend,, weld and modify your z-bar to clearance things, may have to anyway. But my next starter will probably be a Powermaster indexable starter. You may need a heat shield too, I did. '69 Dart Swinger.
      • I8NEMO
        313
        327
        Jul 3, 2019
        Phoenix, AZ
        Local Time:
        5:52 PM
        Well, I'm assuming a mini starter will be needed. Im focused on p/s box clearance right now, jacking up engine tomorrow after right header comes back off. Then I'll get to the starter steering column and z bar. Glad im doing this now and not after paint, still praying for cooler days here in Phoenix. Thanks for your help
      • CRUZE 418
        273
        89
        Mar 11, 2019
        Illinois
        Local Time:
        7:52 PM
        It just seems like the '80's song by the FIX, One Thing Leads To Another. I have had to deal with the starter, clutch, and header issue about 3 times or so, and I don't even have the DART running yet. There will be a new list of gotchas then. Keep an open mind!
        • I8NEMO
          313
          327
          Jul 3, 2019
          Phoenix, AZ
          Local Time:
          5:52 PM
          Affirmative! Getting mentally prepared to install reinstall all the players as many times as necessary. Wishing I would have bought the raw steel headers and ceramic coat later
        • CRUZE 418
          273
          89
          Mar 11, 2019
          Illinois
          Local Time:
          7:52 PM
          You can't protect it forever. If you ever have a cyl get hot, it will cook and discolor the ceramic. Just do what you gotta do.
          It's all a part of it!
          • Like Like x 1
          • I8NEMO
            313
            327
            Jul 3, 2019
            Phoenix, AZ
            Local Time:
            5:52 PM
            So I picked up a starter for a 98 Dakota 5.2. Maybe I got the wrong part but this ain't working.
          • RammerJammer75
            450
            577
            Aug 28, 2020
            Kingsport, TN
            Local Time:
            8:52 PM
            That looks like a chevy starter to me. They've given you the wrong part.
            • Agree Agree x 3
            • toolmanmike
              52,758
              38261
              Jan 18, 2006
              Iowa
              Local Time:
              7:52 PM
              Yep!
            • RammerJammer75
              450
              577
              Aug 28, 2020
              Kingsport, TN
              Local Time:
              8:52 PM
              • Like Like x 1
              • lilfontleroy
                lilfontleroy annoyinglilLeroy FABO Gold Member
                2,685
                2428
                Nov 20, 2017
                Intercourse
                Local Time:
                7:52 PM
                nope, that's the 2.5L Mopar unit, your parts guy wasn't listening to you
                • RammerJammer75
                  450
                  577
                  Aug 28, 2020
                  Kingsport, TN
                  Local Time:
                  8:52 PM
                  Makes sense why it looks like a Chevy starter. Good ole Iron Duke.
                  • Like Like x 1
                  • I8NEMO
                    313
                    327
                    Jul 3, 2019
                    Phoenix, AZ
                    Local Time:
                    5:52 PM
                    Thanks a bunch guys, back to NAPA!
                  • lilfontleroy
                    2,685
                    2428
                    Nov 20, 2017
                    Intercourse
                    Local Time:
                    7:52 PM
                    parts guy is dyslexic :lol:
                    • Agree Agree x 3
                    • I8NEMO
                      313
                      327
                      Jul 3, 2019
                      Phoenix, AZ
                      Local Time:
                      5:52 PM
                      Yes, exactly, receipt shows 2.5l, not 5.2 lol
                      • Agree Agree x 1
                      • I8NEMO
                        313
                        327
                        Jul 3, 2019
                        Phoenix, AZ
                        Local Time:
                        5:52 PM
                        Batting .500 on starters, I'll take it!. I'm pretty close on z bar, somethings just not quite right yet. Ive got the " hooked" bar tab facing down @ clutch fork, and the straight bar tab up towards firewall. Correct? Tear down was some years ago, memory fuzzy.
                      • CRUZE 418
                        273
                        89
                        Mar 11, 2019
                        Illinois
                        Local Time:
                        7:52 PM
                        Z-bar is in correctly., bushing spring clip ret towards the out side drivers side. Clutch pedal rod looks a little off for some reason, don't see the nylon washer either, don't try bending it, it will break. Don't ask how I know this.
                        The dakota starter is close just like mine, maybe closer, I have a Lakewood scattershield. I put a DER heat shield on, will see if it saves the starter.
                      • 1971 CY Dodge Dart
                        1971 CY Dodge Dart Active Member
                        27
                        13
                        Sep 12, 2020
                        East Haven, Connecticut
                        Local Time:
                        8:52 PM
                        Off topic here but loved that band.
                        • CRUZE 418
                          273
                          89
                          Mar 11, 2019
                          Illinois
                          Local Time:
                          7:52 PM
                          Yeah, me too! Had a lot of fun back then.
                        • I8NEMO
                          313
                          327
                          Jul 3, 2019
                          Phoenix, AZ
                          Local Time:
                          5:52 PM
                          Thanks Cruze, clutch rod is just resting there for a visual. At the bell housing, the ball pivot bracket holes don't seem to wanna line up with how the pieces want to align, I've got one bolt in loosely.
                        • I8NEMO
                          313
                          327
                          Jul 3, 2019
                          Phoenix, AZ
                          Local Time:
                          5:52 PM
                          Thanks. Yeah gotta believe heat shield is mandatory on starter. So the damper pulley bolt holes on the new 340 happened to be equidistant. Had the old 318 crank pulley chromed then of course got to elongate the rogue hole. This part of the build seems to be crawling, but im a determined guy.
