Hi Mike, Sanderson DD9 for auto,Manual steering.
Was debating on using with hydraulic clutch.
Ol' Blue's magnum swap
Dave
Dave
I tried ordering them with that promo code and I keep getting a message saying it cannot be applied. I have tried chatting with a customer service person and have sent 2 emails; I have yet to receive an answer that adequately explains why this code cannot be used.
Especially if others are getting this discount.
Maybe they're considering them an oversize item, which the discount does not apply to?
Dragnut, if you run TTI headers you will have cut, and modify your Gerst Kmember along with taking a hammer to your $800 headers. That being said, i feel it was worth it, and no structural damage was done. After all that's what hot rodding is all about. As for Dougs I have no idea about there fit.I am also trying to figure out what headers to buy for my 66 Dart, im running a 360 mag. with a Gerst front suspension, rack steering and a Tremec 5 speed, Hydro clutch...I see Dougs makes a set of headers that work with the Alterkation front suspension (D454)....not sure about the Gerst
After all the home work, Dougs 450 on the way for my 66 Barracuda.
Tim
Those TTIs are bent on the driver side to go around the power steering unit and that pipe runs right over where my Hydraulic slave cylinder is for the throwout bearing. Since im running a rack for steering that bend is wasted space...Think im going with the Dougs D454sDragnut, if you run TTI headers you will have cut, and modify your Gerst Kmember along with taking a hammer to your $800 headers. That being said, i feel it was worth it, and no structural damage was done. After all that's what hot rodding is all about. As for Dougs I have no idea about there fit.
I would like to Know how how the Dougs Headers fit. Please keep us up to date. If you want to see pics of the mods needed for TTIs go to my restoration page. Good luck on the DougsThose TTIs are bent on the driver side to go around the power steering unit and that pipe runs right over where my Hydraulic slave cylinder is for the throwout bearing. Since im running a rack for steering that bend is wasted space...Think im going with the Dougs D454s
Thanks...I will post some pics when i get that far...I would like to Know how how the Dougs Headers fit. Please keep us up to date. If you want to see pics of the mods needed for TTIs go to my restoration page. Good luck on the Dougs
Snooping on your post, I see that Dart is in very capable hands. looking forward to more pics.Thanks...I will post some pics when i get that far...
Well i can tell you now that the Dougs do not fit...A $550. lesson...Im going to look at the DD7 Sandersons...they look like they may work for my setup..Dragnut, if you run TTI headers you will have cut, and modify your Gerst Kmember along with taking a hammer to your $800 headers. That being said, i feel it was worth it, and no structural damage was done. After all that's what hot rodding is all about. As for Dougs I have no idea about there fit.
Thank you. Am resigning myself to the Doug's D-450. The Jegs' detail says no on column shift which mine is. Is yours and the solution is a little denting? I have side pipes which previously were matched to long headers on a 1974 Coronet (first car). Not sure if the length will work on a Barracuda. Shorties might be better for me but now thinking pretty with an aluminum Champion 166-CC526 radiator and ceramic headers.
Thank you again. You nicely wrapped all that. Why are 64-66 so difficult to buy for? Worse than a … May build some if I can't find shorties.
