Get real. Horsepower takes fuel. When you say "roast the tires", you say, "To hell with fuel mileage."
You need to set reasonable goals for power and mileage and go have fun.
I got the best of 20 mpg’s with a 4bbl equipped 360/904/2.76 gear with 235/60/15’s, in a ‘79 Dodge Magnum.Start a new thread..."what are your build specs, mileage and performance"
..i'm betting there are small cam,14 " tire combinations out there that will get lots of rubber and 20 mpg!
I definitely think handling should be on the list of improvements.Besides power and mileage, there's another aspect that can be very satisfying to have in an old car, and that's good handling.
Especially for a young guy he might like a good handling car that can take corners and have it handle like a more modern car.
He's not going to get 20 mpg in the type of driving mentioned - not even with a slant 6. The new goal is now not getting worse than it has witrh more pep, and that's doable.Start a new thread..."what are your build specs, mileage and performance"
Yes. With more pep, good stopping and turning are a great idea. Factory front sway bar is a minimum.I definitely think handling should be on the list of improvements.
There's a lot of threads about 318 cams here on FABO. For mileage and efficiency you should keep the duration at 220° or below. Much more than that and you may need a higher stall torque converter to make it work. Here's a couple threads I saved. Within this thread are links to other 318/cam threads. 318 Build on a small budgetI would agree with the 3.55 gear ratio being a good balance for getting the best of low end off the line with a balance of it drinking fuel. Provided of course a lighter foot on the pedal, accompanied with a 4bbl carb and intake combo, 258-268ish cam, dual exhaust, and an od transmission would get it in the range of a semi economical rompity car.
Whatever you do; do not put 74 plus cc heads on that 318 with a 340 cam, and 3.23 gears or less, with the stock TC. I did that once back in about 1980,and it was a total waste of time. The Dcr was so low that, (I didn't know about Dcr/VP back then), that 73 Swinger felt like it weighed 5000 pounds. But it had pretty good passing power at 75mph.......... in second gear!Eventually I put a 2800TC on it and it was still doggy down low. Finally I put 3.91s in the back, and that sorta woke her up. But gas mileage? Fugedabowdit!Okay guys, here is what I'm wondering. My son and I are bench building options for his bone stock 1971 Plymouth valiant. Current set up is 318 2bbl 904 stock. He loves the car, but has been wanting to give it some pep but wants to retain drivablility and gain some gas mileage. So he is thinking aluminum heads, aluminum 2bbl intake manifold (yes, I said 2bbl aluminum) he says they exist. Dual exhaust and mild cam. Gear change out back. I think that the way to go would be keep the iron heads, stock 340 cam, 4bbl intake either stock steel or aluminum, and carb to match, dual exhaust and a set if 355's out back. Put all the stock parts on the shelf to put back stock if ever wanted. What do you guys think?
That wasn't even 5000rpm yet. The math says 4500rpm right about where the 340 cam begins to come alive, snuggled into about a 6/1Dcr 318 . That was my all-time worst combo. I was about 25, and dumb as a brick. But hey,I had just found me a wife in 77, and the plumbing was working. I had my first baby, a daughter in 1980. So there's proof right there, that even a DA kid ......................... can find someone to love.Good advice. I can't imagine 75mph I'm 2nd gear, that's Bonneville salt flats right there!
I’d vote turbo except of tubing concerns and cost and headache and....Horse power and mileage says turbo to me, out of boost to low boost good gas mileage, in boost horsepower.
OH! No you’ve done it!!!!!I've got a 1970 low mile j headed la360 sitting on an engine stand in our spare room. Lol. It's a concrete floor. Has a 4bbl aluminum intake and edelbrock 600 cam carb. It's ready to install, has a 727 trans sitting with it. So cost to find is zero. My son is welcome to use it in any project he wants. He has just been saving it for either the resurrection of his 68 fury or our 74 amc javelin. He just likes the idea of using the original engine in the valiant. Which is why he has been basing all the plans on the 318.
That is impressive without a doubt.Not necessarily, but kinda yea
I run 80mph at 2,100 rpm's on the hiway getting a hair over 25mpg and can still light tires just fine.
1996 5.9 Magnum 9:1 carbed
214/224 cam
A500OD with lockup
15" 60's on the back
There's no way I can get into the cam power range in anything higher than 3rd.
In OD I would have to be doing in excess of 140 before the cam even starts building.
