oldkoot
Newbie Mopar owner question.I have a 67 Dart with a 273, Edelbrock 500 cfm carburetor.When cold it starts perfect , just tap the gas to set the choke and starts fine. When the engine is at operating temperature and shut off and then try to restart after say 10 minutes it acts like it's flooded but the throttle plates are dry(no gas leaking from the pump nozzles,checked float level and fuel pump pressure-OK). If you just crank it over without touching the gas it wont start but with a little throttle it starts right up. Is it normal for a Mopar to need a little throttle for starting when hot? Sorry if it sounds like a dumb question but every other carb'd car I've owned you didn't need to touch the gas when warm?
