Ride height is easily addressed in several different ways. The main issue is those springs are too long. If you want that (type) spring I'd ask Hotchkis if they can exchange them for a set about an inch or 1.5 inches shorter.
I belive Hotchkiss assumes people using these springs are doing major fab work building a car anyway and will not be concerned with what they probably deem a minor fitment issue for drilling new holes like jrlegacy23 did. A new hole in a more favorable location there would solve your problem and potentially add some lift depending where you put it.For the record, I did call Hotchkiss and ask for designed install heights, and they had none."
If they sit at 0 degree arch like 72BBSwinger said, they can move no direction but forward with flex....but i can almost guarantee that any slight bump i hit on the road and the shackles will be slapping the subframe hard.
Bad idea. Those springs won't work right except left the way they are...add a shorter leaf or 2 from the /6 springs...
340-4spd:
It would if i had relocated my springs like he did, I however feel Hotchkis' targeting market is the bolt-on mechanic...I see myself as in between these two extremes, and had relied on Hotchkis' engineers to design something that has proper suspension geometries once installed. When its application specific like '67-76 A-body leaf springs' i assume most of the research has already been done. But as has been proven time and time again-never ***-u-me anything
72BBSwinger:
I noticed the relief on the stock shackles, so lets assume that will give me some clearance at static ride height. The stock hanger will move the height up an inch, maybe give me more clearance, but i can almost guarantee that any slight bump i hit on the road and the shackles will be slapping the subframe hard.
The shackle angle has marked effect of leaf spring tuning characteristics. The "preferred" angle of the shackle depends on what you are trying to accomplish with the rear suspension:The rear shackles are perferred to angle back a little. No matter what leaf springs you have on there. It's ok to have them angled foward. but angled back is perferred. I think that is stated in the Super Stock spring instructions. No sure. But it is stated in the Mopar Peformance Chassis Manual.
- You are running a modified/cut down? Dana back there. What is your pinion angle on that Dana? Where the perched welded on with the right pinion angle.
- You have aftermarket rear shackles. Are they stock height?
- You are running a T56 trans with a homemade trans mount. The engine and trans may be angled up or down from stock position
- You have a solid motor mount. The engine and trans may be angled up or down from stock position
If you ordered the rearend directly from Strange, the spring perch to pinion angle will not be correct for a "stock" A-body. Unless you specified otherwise, Strange installs the default perch/pinion angle at 7 degrees positive, which is correct for an E-body but 2 degrees farther up when installed in an A-body.
To further compound the problem, because you installed a T-56 transmission, you can not confirm your pinion angle or driveline angle, until you measure every thing correctly.
You can install stock A-body front hangers and shackles and reset the pinion angle based on the transmission centerline NOT to the ground, NOR to the driveshaft.
In other words, AFTER you correct the hangers and shackles, when the vehicle is resting on its suspension, make the pinion parallel to the transmission as a base-line, then roll the pinion downward 2 degrees and reweld or shim your perches. The result is a true 2 degree negative pinion angle.
The 5 degree thing is not what you want. The driveshaft angle is irrelevant its the pinion angle in relation to the transmission tailshaft that needs set 2 degrees down from parrallel.
No 2 degrees "down" from parallel on the pinion. Minimum. Especially with those springs, unless you have some wrap control. I'd guess you'll probably want 3 or 4 degrees down if it's making much power.Yes, ive found a few good diagrams...make the trans and diff parallel
