After looking at Drewmac's pic and seeing he went through the triangle shaped hole on the bracket, I ended up drilling that out and doing the same.
View attachment 1715579880 View attachment 1715579881
Sweet! Glad to be of service.
Nice.
Very cool drewmac and kursplat were able show what they did in same situation and help.
You’ve done some real nice work and detail on this car. Don’t let your foot off the gas.
@drewmac did you shorten your end links?
I see it was suggested but I can't find if you did or not.
Please do.I can measure them if you want.
Sorry this took so long. The distance between the center bushings is 2.5 inches.Please do.
I have new ones on, so also wondering if they'll have enough thread on either end.
So, I'm bored, it's frigid out, and I've got my k-frame inside with QA1 lowers and a Hotchkis sway bar.
First, read instructions.
I initially bolted the frame brackets to the k-frame first, using the front hole for the original sway bar bracket, but it was clear the other hole did not line up, and if I just drilled it out, the sway bar would bind up in the bushings/brackets.
I'm skipping 3F for now as I have the QA1 lcas.
Bolt on the sway bar bushings, brackets, and frame mounts - done.
Lined up the front holes, 1 on each side.
A few issues, in my mind anyway.
The brackets do not sit flush against the k-frame for 2 reasons.
The factory weld seam at the edge, see pic with washer.
Also, when they bend the frame brackets the metal curls, or bunches up, at the corners, causing high spots, see pic.
So, the plan is to grind some clearance for the weld, it's more of an issue on one side, and grinding off the high spots at the corners.
Once they are flush and the bar is level to the k-frame, I think I'll bolt the front to the original hole, and weld them on.
The other triangle hole in the bracket is not even close to the other original hole, see pic. I'm not even going to bother trying to drill a round hole in a triangle, hole.
Last thing, granted the k-frame is upside down on the floor, and the brackets are not flush, but the end links appear to be off by 3/4 of an inch on both sides.
Once everything is back together, the k-frame is in, new sway bar brackets on, if I have to relocate the lca end link brackets, or weld on the ones they provide, or whatever, so be it.
Done.Please take a few wider shots of the brackets on the K memeber
They actually sent me 4 frame brackets, I painted 2, and 2 are still bare steel.after doing mine, i wouldn't even attempt it off the car. too much adjustment prior to welding the brackets
A better pic showing how the edges are not flat.
The pic shows the side that's raised more due to the larger welded seam.
It's more obvious on the other side how it prevents it from laying flat, but harder to get a good pic with black against black.
yup. also mine did the same thing. cut some filler pieces out of 1/8" and weld it all together. looks good...In my mind, the big takeaways are to mount the brackets to the sway bar first, then determine where the brackets need to be on the k, and get them flat against it.
Behind. Sway bar is more above the bottom of the k than below it, and that's with the brackets tilted at an angle due to the welds.
Granted, on the car the k is more at an upward angle towards the front than in this pic, but the sway bar would still be in the same area in relation to the k.
In any case, moving the lca up and down, it doesn't get any closer to the end link than 3/4.
That is going by the specs that the end links must be vertical, and I'm interpreting that as meaning vertical to the seat in the sway bar as well as the lca end link mount.
It doesn't appear to mean perpendicular to the ground, I imagine they would state it that way if so.
Also, instructions state the span between the end link brackets, on the lca, must match the width of the sway bar.
They do not, hence the 3/4 difference on both sides.
I really want to get it all on the car and see the geometry when it's at ride height before saying it lines up or not, or is within a reasonable tolerance, or whatever.
Just showing what I'm seeing now.
Using the factory bolt holes in the front lines it up very well, side to side and front to back, and the reality is moving it forward, back, side to side, doesn't get it closer or in a better plane in relation to the lca.
If I had just bolted the brackets on the k first, the sway bar would bind up, of course that would mean I didn't read the instructions.
If I undo the bar placing the bracket would not be accurate.Can you undo the bar and just do a bracket shot straight down? I just want to see where the triangle hole lines up.
I think we're talking the same thing.cut some filler pieces out of 1/8" and weld it all together.
definitely, that thing hangs down far enough as isThe angle of the bracket doesn't matter, but the placement does.
