dibbons
Do the hold downs hook from inside the battery tray out or the other way around? Thank you.
What? It should be obvious. Short hook to the fender.only one way for that one to go. Inside out is what I have seen. You might have to dig around for old photos or look in a service manual.Do the hold downs hook from inside the battery tray out or the other way around? Thank you.
This model is for 64 and earlier.Do the hold downs hook from inside the battery tray out or the other way around? Thank you.
