Is it shifted with an internal cable system ?.. I also had a 64 dodge A100 pickup that had a cable operated 727 ( thing is the cable operated external shift lever) the A100 did not have a parking brake on the trans.I have a 64 727 out of a truck, has the park brake drum on it
When I was looking for info for the converter I bought from a member here for my a500I'm not sure but I think all A-500's were lock up. A-518 were either/or lockup/non lockup. If you don't want the LU function on a A-500 it can be disabled in the valve body.
Yup. Internal cable. Only has the kickdown linkage sticking out the top.Is it shifted with an internal cable system ?.. I also had a 64 dodge A100 pickup that had a cable operated 727 ( thing is the cable operated external shift lever) the A100 did not have a parking brake on the trans.
