68383GTS
Buy a cell phone..LOL
No holes for that type of a mount. It uses small allen head screws which pinch the mount to the trunk lip. The mount has rubber on it so that the paint won't scratch. The only place that paint get's messed up is on the underside of the lip where you want the allen screws to penetrate the paint so you get a good ground.
I have seen mag mounts fall over and scratch the hell out of paint.
This is a really good antenna and mount:
Wilson 1000 CB Antenna - Trunk Lip Mount - YouTube
how about tradin your CB in for a cell phone.....LOL! ( just kiddin) I used to use that clear film used for protecting paint on vehicles.
Try some clear vinyl like they use on "Clear" bras. Make sure the surface is clean, and when you set down or remove, pull straight up.
Stuck in the 70's... LOL
In my opinion, if you have a GREAT paint job (I don't) you are probably way ahead to scratch (pun intended) the idea of a mag-mount antenna.
For one thing, all you'd have to do is hit one low tree branch or similar problem, and that might just knock the thing off and down the rear/ side of the car.
They don't work all that well, but you CAN get "dual" antennas which replace your automotive car radio antenna. These have a coupler, and are specially built to operate on AM, FM, and CB
I did once have a couple of truck lip mounts that clamp on, but they STILL are capable of marring the paint, and especially if the trunk gap is "tight" vibration/ movement of the trunk lid may result in damage to one side or the other
If you are "handy" and especially if you have a trailer hitch, consider building a removable bracket to attach an antenna coming out from under the bumper. You can buy what is known as a "1/2 wave design" for fiberglass boats which do not need a ground plane.
If you just use them to communicate on road trips get one of the cheap hand held ones. They work well and you don't need antennaes (?) and such. Plus if you are at a show or cruise you can keep it in your pocket and still communicate with others you are sepparated from.
Then you need an adhesive-backed mylar disk affixed to the bottom of the magnet.
I can only find ones online about 5/8ths of an inch. Do you know of where I can get large ones?
You haven't shown any interest in my tow magnet rubber idea but just on case I will post this picture for you to see.
Not off hand, but you probably could get away with four or five stuck to the bottom.
Where can these be purchased and would they leave anything on the paint?
I have a cell phone but when our car club gos on trips we use the CBs
They are what the proffesionals use. They will do no damage to the paint and I have hauled 1000s of cars with not one scratch. Many cars were 50K+ cars. They are designed for that reason. They are made for the magnetic tow lights that are attached to the towed vehicles trunk lid or roof. Those are on eBay for about 7 bucks but the seller wants like 13 bucks shipping. A tow supply company should have them. Here is the ebay link and these are too high priced on the shipping.
http://www.ebay.com/itm/Magnetic-to...her_Vehicle_Parts&hash=item2a1f6f64ed&vxp=mtr
You might check this wrecker supply and see if they stock them. http://www.awdirect.com/
Rubber Magnet Covers
Fit all 3 to 3 1/4 diameter round magnets. Imported.
http://www.awdirect.com/rubber-magnet-covers-mb100/tow-lights/
They also have the Bruise Tape
Use this self-adhesive plastic film to protect your customer's car from the minor "bruises" that can be caused by magnetic tow lights, door tools, tow straps and more. 5 mil thick, this clear tape comes in a convenient 200 foot roll and is perforated every six inches. Simply tear away at the length you need and stick it to any metal or glass surface. 6"W x 200'L roll. Made in USA.
http://www.awdirect.com/bruise-tape-bt260/tow-lights/
Another way is to get one of these and used the magnet or rubber of it with your antenna.
