moper
Yup. You can always use solids where hydraulics of the same design were used. Going the other way can prove problematic tho.
I'm about 2 weeks away. Will be interesting to see what happens with the retros. I'll post my results here too. What rig is your motor going in. Do you plan on running it on a Dyno??? our engines are similar other than compression and mine will be running a Fitech 600 power adder but normally aspirated. It will be interesting to see the power of both engines... I'm sure yours will pull more than mine...I'm limited on flow with my indys compared to your eddys. Not interested in competition, just interested for future reference one motor head to another.Got the new lifters from Hughes and got the engine back together. Took the new lifters and blew air through them before installing them. Air came out of the oil hole. Got the engine running and everything sounds good. No ticking or any unusual noises.
Now to do a good tune on the engine and see what she does.
i can't get any set of flat tappet lifters to hold over night , even without rocker arm load . some will hold pressure , never the same bore . get i got to go one good one at a time . i've got a bench full of lifters , here goes day by day . pulled the plugs so it rotates easy with the start , turn it over with the starter until i get pressure up lifters , then a few more to keep it there . and come back a day later and check them for piston plunge , keep the ones that hold . and replace the rest . start it again . anyone know a better way ? please tell me . and no the customer wants a quite motor the start without any rattles . even after a month or more of setting . its just a clean driver , i want the same thing for him . it just a 340 la block and heads , nothing trick , just well dome .
Sounds right to me...I thought that when a lifter on the lobe is in the valve closed position the check is in a position to allow oil into the bottom compression chamber. The compression chamber is sealed when the lobe comes around and begins to lift the lifter...pushing the ball back onto it's seat and retaining pressure in the chamber. Normal leak down comes from the pressure chamber back to the reservoir between the plunger and internal lifter body bore. If my understanding is correct, I would assume they should leak down with the engine off.Sounds like all your lifters are working properly. they all will bleed down over night.
I've had the valve covers off and after turning off the motor I can watch the lifters bleed off of a lifted valve with a dial indicator after several minutes. Comp hydro flat lifters with an xe268h. No lifter tick at all and the 318 goes like hell.All i know is that when i would pull my valve cover off the next day, valves that were on there lobes had collapsed. Ss in, the lift at the spring had been reduced. NOT that the valve train was loose, just that the spring pressure was reduced.
No clatter at start up...........which is why i made my statement above.
And these were Mother Mopar Hyd Lifters of 10 years ago.
Glad it's fixed Marland!
