64dartwag
Does anyone have any experience with this camshaft? the description on Hughes website specifically says its for low compression engines. just curious if anyone had used it and how well it performed.
That's why i was curious. I seems small to make any kind of rumble or much of a power gain.
It's not a performance cam it's a tickle your ego cam or at least it's supposed to be...
Doug Dutra talks about (and seems to prefer) the reverse pattern/I thought I had a cam picked out for mine but now I aint so sure.... but my build isnt an A body.... most likely going into a D150, "might" instead find its way into my Volare.
When you call Oregon cam grinders (in Vancouver Washington LOL...) Ask for Ken. He's the owner.. since I'm close I just go up with my Cam and lifters and have them done the way I want them. Pretty much he can grind whatever do you want...Oregon Cams probably would be the best bet. They have slant experience and offer some of Dougs profiles. I’ve not dealt directly with them but I have one going in. I understand that they would be glad to discuss and recommend something. But like I said I’ve not dealt directly with them so I can’t back that 100%
.. not mine...
Look again at my post.... and the one you copiedThat's not a slant six. That's what the OP is askin about.
Every time he gave me what I wanted even when he tried to talk me out of it he still gave me what I wanted LOL...
.. not mine...
This is the setup I truly want to run. I love the look of it. I am so happy to see that two factory air cleaners fit. it looks amazing. I am looking mainly for bottom end grunt. My little wagon is not going to be built to out run an ls or anything but I do want better red light to red light performance. I prefer more torque over hp personally. i have been looking at building a "long rod" /6 ever since I got the car from my brother. it is mostly all original and I really don't want to V8 swap it. I have fallen in love with the slant. I guess I need to just buy Dutra's book and do some more reading. I don't expect to have a super choppy idle but a little bump would be nice.
Biggest bang would be the Oregon cams 2106 (easy), Dutra RV10RDP (hard if Doug lost his stock in the fire) and the Dutra duals with the pipes run back at least behind the transmission cross member before the collector back into one pipe (much harder). Easier if willing to go to a mini starter but I am on a mission to make this work. Make sure you time the cam. View attachment 1715633145 View attachment 1715633146 View attachment 1715633147
Pure Beauty Sir!!Biggest bang would be the Oregon cams 2106 (easy), Dutra RV10RDP (hard if Doug lost his stock in the fire) and the Dutra duals with the pipes run back at least behind the transmission cross member before the collector back into one pipe (much harder). Easier if willing to go to a mini starter but I am on a mission to make this work. Make sure you time the cam. View attachment 1715633145 View attachment 1715633146 View attachment 1715633147
Pure Beauty Sir!!
