Before you take that jump I would try to verify that you have a carburetor problem. Then decide how you want to correct it. You may have a plugged idle circuit rendering the idle mixture screws useless. See if it’s lean at idle by forcing it richer with a hands over the carburetor choke test. It won't cost you a dime.the spacer and gasket are good, I just had the carb off to re-do the transfer slot adjustment.
the carburetor is already a remanufactured one that was put on in 2008 that I rebuilt because It had a bunch of oxidation all inside it.
the thing is just tired. I'm thinking of getting this thing at my local discount store.View attachment 1715850492 View attachment 1715850493
