jaygray
New Member
Are you replacing the rear main with the engine still in the car? Pull it. The job will be cleaner and you'll be able to see what you're doing.
Take the cap to a Machine shop and have it filled with spray weld. Then have it drilled, threaded and reface the pump surface. I would bolt and torque it to an old block we have when welding it. Spray weld is the correct way . You won't even see where it was welded. And leave the engine in the car.
I've never seen heli coils hold up when used in a stress area. I have a friend who had a block where the machine shop used heli coils in the cylinder head bolt holes, it never held a headgasket after that. The cap is a breeze to install, the problem is having the block align honed
It might not fail with a stud, I've seen them fail with the use of bolts. I do wish you the best of luck.Well then, we will see how I do. I’ve got a BBC on the dyno that has a helicoil in a head stud hole.
I’m betting it won’t fail.
The chances of fitting a main cap and cleaning it up with a line hone is slim. You have to line bore them.
If I take the cap off do I still need to hone the block?Take the cap to a Machine shop and have it filled with spray weld. Then have it drilled, threaded and reface the pump surface. I would bolt and torque it to an old block we have when welding it. Spray weld is the correct way . You won't even see where it was welded. And leave the engine in the car.
You half assed it so far and look at what it got you.I'm not gonna lie to you guys I half assed it threaded it and put a longer bolt. It has less than 10k on the motor from what he told me but I'm gonna put a bigger motor down the line regardless but for now I think I should be fine I hope? That's a tomorrow problem lol I know I shouldn't half *** it but it is what it is thanks everyone for your guys help seriously I thought I was done for lol
I cannot agree. There's no way in hades that cracked in two places bolt hole will hold a thread sert or a heli coil. Ain't happenin. At least not for long.It looks like there is already a heli coil in the other hole. Someone probably used bolts that were too long and cracked it. A thread sert would be more than sufficient to repair that. Yeah, heli-coils are awesome but on something like that I would use a solid thread sert.
What do you mean? It was my first time opening the oil pump.You half assed it so far and look at what it got you.
If you use the original cap it is already sized to your block. Take it off , Fix it and put it back on, If the bearing looks good reuse it.If I take the cap off do I still need to hone the block?
Just quoting you, buddy. You said it yourself. Anything other than another main cap and align honing it to mate with the block is half assin it. You've already see the results from you half assin it the first time, just like you said in that quote up there ^^^^^^. Do it right and it'll turn out fine.I half assed it.................
refacing the pump surface would be an issue.How about a brazed stud, then use a nut to secure the pump? Could that work?
I think it happened when I tried to torque it. This time I just did it by hand. It looks like it was machined both sides before it was put together.You don’t think that was my first repair like that do you?
I’ve been doing this a LONG time and I’ve never EVER had one fail. So if you or your buddy is failing them, take a look in the mirror.
It’s essentially the same repair for spark plug holes. Zero failures there too.
I don’t need luck.
That too. Whatever it takes.Well then, we will see how I do. I’ve got a BBC on the dyno that has a helicoil in a head stud hole.
I've never heard of a heli coils hold in a cylinder head bolt hole not to say that they don't work. We wasn't the one's who installed it it was the machine shop, after the heli coil failure the block was junk. Are you using something other than a heli coil ?You don’t think that was my first repair like that do you?
I don’t need luck.
To do it right, YES!!Wouldn't the block need to be alignhoned:
