BigSlim
"One Day At a Time"
If you run a hot wire from the battery to the negative side of the coil shouldn't it start and run? That would prove out that you have an issue with the ballast resistor or the switch. Yes / No ...... Any thoughts???
Ballast resistors fail. Period. But the classic failure shows up as an engine which starts, and then dies when the key is released. Remember the ballast is bypassed when cranking, giving full voltage to the coil. Sounds more like a bad ignition switch, relay, or dirty bulkhead connector. (You should see 12v at the coil when cranking, and 9v when running with the key released). Replace the ballast anyhow, it's good to have a spare.
How long was the car not running/driving while you had the engine out? Did it sit for a while with the hood off? I think you have another electrical issue, especially given the grief you had starting it the first time.
That wire would go to the positive side of the coil and the original wire would need to be removed, just incase there is a short to ground in the original circuit.
Shutting the engine of at 2500 RPM shouldn't have hurt anything internally. Snort, pop or run-on would have been normal given the fact that the throttle blades were open a fair amount. But a good backfire might have popped a vacuum line, so look around.
Wiring diagram for your viewing pleasure: http://www.mymopar.com/downloads/1973/73ValiantA.jpg
Bust out the multimeter, and see where you are (and are not) getting voltage before you go around bypassing stuff (although briefly installing 2 jumpers in place of your ballast should be fine).
Running directly from Bat+ to coil+ works on points, but is pretty dangerous (engine won't shut off with switch). Besides that only confirms there is a problem (which should be obvious due to no-start) but does nothing to pinpoint the location of the problem.
FIXED!! Thanks guys!!!
It was the ballast resistor! I took the old one off, and it was fried in the back. it was pretty obvious. I put on the new one (4 pin) from Autozone for $4.00, and it fired right up! I let it run for 20 minutes at 2,500-2,900 rpm and it was perfect! It did get pretty hot but not to the danger level.
I was worried so much about the engine that I forgot about the transmission! EEK! I'm letting the car sit now for 24hrs, and I will go on from there!
Thanks a lot guys!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
When you've blown a battery up in your face, you tend to avoid alligator clips!
Long story short, the battery says "Avoid Sparks" for a reason.
Anybody who wishes to try such a thing is welcome to it. I just never told them to.
