I'm thrilled I got this hood for my Dart...
A dumb question, I'm not aware of
Any plastic plate/cap to keep water from dumping in the engine compartment on stock scoops, but I have seen others that do. ???
I haven’t seen plates but the gasket that goes around the hole will stick up about 3/8” above the surface of the hood which should keep surface water under control.
This is true the rubber seals that go in th e4 inch holes control the water from getting in under the hood save for a mist or droplets etc.
I don't have any holes in my hood and I have the scoops. Zero issues with the studs breaking or the bracing.
Me neither.
