Initial timing
4spdragtop
Ontario Parts Unknown
While trying to rectify a hard start(Eddy 9266 ordered) I figured I would check initial timing and proceed from there.
With vac advance disconnected, I plugged the vacuum line to carb.
700 RPM in park and 30* initial.
Seems like a lot?
Verified TDC with piston stop.
Set #1 firing at 10* BTDC.
67 cuda over cammed 273 with 340 sft.
MP elec ign.
30 is insane inital unless distributor is locked or weights
are frozen in place! No wonder it is hard starting.
I would inspect/clean distributor and maybe put heavier
springs in it.
Does the lead go up if you rev the engine up to 3000 or
stay the same?
My 5.9 likes a ton of initial also. Funny, I was just working on my timing today. I set it back to 20 and I'll see how the plugs look after some drive time. The plugs definitely showed too much timing at 30.
It got me to thinking about accuracy of the timing light and I found this thread. No definite answer, but it sounds like they don't go bad too often.
Distributor is not locked. I know the spark plug lead to gun has seen better days and should be replaced.
Timing at idle is steady. When I adjusted to approx 15* BTC, it barely idled.
Yes, 30 would be a lot unless the distributor is locked
30 is insane unless distributor is locked or weights
springs in it.
stay the same?
30* @ idle can be too much.
Or it might not be enough.
Over cammed 273. Would not take much to over cam a small engine like the 273.
But help is at hand!!
Here is how to determine initial timing for that combo:
- disconnect & plug VA unit.
- get engine warmed up, idling, in gear if auto trans.
- loosen dist clamp, turn dist slowly to advance timing. Keep advancing dist until rpm peaks. toggle dist to make sure you have the highest rpm.
- now check what the timing is. That is what THIS engine wants for best idle AND tip in response. If you use vac adv connected to man vac [ MVA ], you can use any combination of MVA + init. Example: best idle was @ 36*. You could use 18* init + 18* added by VA.
An engine I tune for drag racing reqd 53* for best idle with one of the cams we were running.
Just an example.
What is the total timing? 30 is a lot of initial and I doubt it has an 8 degree curve in it.
If it idles at 30 degrees and you back it off to 15 and it wont idle, that is normal. The idle will drop when you pull initial away. Adjust your idle setting.
You really need to start by setting your total to 38, lock it down and see where your initial falls. That may be all you need. If you need more initial, you will need to restrict the advance.
You gotta set your TransferSlot exposure underneath the primary throttle valves first. If this is not done first, then you will be chasing your tail all over the place. The starting point is from dead square to a lil taller than than wide, depending a lil on the engine combo. Then set the mixture screws into the middle of their adjustment range, which is about 3/4 turn on Holleys, and 2.5 turns on most others. Then close the secondaries up tight but not sticking.
This is your starting point. After this DO NOT adjust the idle Speed screw. After this, you will set the Idle-Speed with Idle Timing in the range of about 10 degrees to at most 18*, depending on the combo.
In order for this to work, the following must be correct; namrly
1) the float level is correct and remains stable at all times
2) The PCV is correctly installed and plumbed to dump air just below the primary throttle valves.
3) the brake booster does not leak
4) the engine does not have any vacuum leaks, including not into the valley.
5) the engine is in good mechanical shape
6) the installed centerline of the cam is within a few degrees of "straight up"
7) the pistons move up and down freely
8) the engine and it's oil, are up to operating temp of ~185 or more.
9) the convertor is properly slipping
10) some engines are gonna need some Idle-Bypass Air, to get the rpm up, and to get rid of the "burns your eyes exhaust stink..
I hooked Mighty Vac up to va, plates move at 9"hg and stops moving at 18".
if your Vcan has a hexagonal shape at the spigot, those are adjustable as to their cut-in/finished calibration.I like to set them to come in as early as possible, so long as it does not induce detonation.
Your engine/all engines, have a very small window of best timing. It is, generally, whatever it takes to get the peak cylinder pressure to occur at about 25 to 28 degrees AFTER TDC on the Power-Stroke. At this time, the crank is in the best position to receive the energy of the hot expanding gasses, and send it on down the line.
At full power WOT and beginning at around 3600rpm, this point is usually achieved with a Power-Timing of 34 +/- 2 degrees.
At Idle it usually occurs with MUCH more Initial/base timing. Usually in the mid to high 30s , but as Bewy discovered in post #7, can be even higher.
All your factory timing mechanisms are designed to hit that optimum crank position, as often and for as long, as possible.
You can easily find this position at idle, just by advancing the crap out of it while re-adjusting the speed screw to keep the idle speed down. However, by adjusting the speedscrew, you shut off the Transfer Slots, and this is bad news. Yes, you can readjust the mixture screws to compensate, and it will idle; but this introduces other problems like; the dreaded tip-in sag, or a hesitation, or an outright bog, and an impossible to cure low speed rich condition. You will end up spending ridiculous amounts of time with the accelerator pump and float levels and IABs.
Furthermore, with mega Idle-timing comes a major increase in low-rpm Power. This leads to a hard N/P shift into gear with a typical stall convertor. But worse is that it makes the low-rpm throttle application quite sensitive; that is to say, tiny amounts of throttle application are immediately felt as acceleration; sort of like an on/off switch. If you have a manual transmission, this is exceptionally aggravating as the car gets jumpy. And, of course, the starter doesn't like it either.
IMO, and
for a streeter,
there is no good reason to run mega-Idle-Timing; it creates more problems than it solves. For that reason, do I recommend setting the Idle-Timing AFTER the T-Slots exposure is set; because it will automatically cure most of your problems.
Your low speed fuel-delivery circuit is comprised of some combination of the mixture screws and the Transfer Slots. You can vary the proportion of each, by experimentation, to whatever gets rid of the tip-in sag, while simultaneously setting the off-idle AFR leaner and closer to 14.7.. To help with that, what I do is this; set the rpm to 2000/2400 with whatever fast idle step it takes. then adjust the mixture screws for lean best rpm. They should fall into the range of about 1/2 to 1.0 turns out on a Holley, and about 2.5 turns out on just about everything else. Then flip out the fast idle.
Now, leave the mixture screw alone. If your idle wants more or less fuel, you get it from either the T-slots by the curb-idle screw, or the IABs by swapping/drilling. If the Idle speed gets out of whack, simply change the timing to get it back.
Here's the deal;
In my 11/1 367engine combo I have run three different cams, from the 292/292/108 Mopar, to the Hughes 223/230/110, to the current 230/237/110 Hughes, and I can tell you that ALL THREE of them will idle all day at 5* advance, without overheating, without a tip-in sag or hesitation, all of them pulled themselves around the parking lot with a manual trans, down to 550 rpm, and one of them got me 32mpg on a certain all-day test run. What I'm saying is this;
IMO, there is NO good reason to run mega Idle-timing, except perhaps for emission reasons. But yes, with an auto trans, you can usually get away with it ...... especially if the car has a hi-stall in it.
Let the T-slot exposure be your guide.
Adding Idle-Air bypass, allows you to close the throttle back down, to get Slot exposure down, to get the Idle AFR back in line, to get rid of the Tail-pipe burns your eyes stink. With too much Idle Air, the T-slot exposure will become too small again at a decent Idle-speed; SO; easy on the bypass-Air. You can experiment with Bypass air in/into the PCV circuit. If you do NOT have a 4-corner idle system, then I highly recommend NOT to introduce this bypass air by cracking the Secondaries. In my experience this just makes the rear cylinders lean.
My best advice is to set the T-Slot exposure first. This will make/force the other parameters to fall into line.
Once the amount of bypass air if any, is established, I drill the throttle valves. One hole in each Primary. On the front side, between the T-slots and the Idle discharge ports, but no closer that 1/8th inch from the edge. The bigger the cam, the more air it will need.
My 292 Mopar/[email protected] cam required two holes total, each one being 7/64= .109inch
My [email protected] required NO holes.
My [email protected] cam also has no holes, but I think it wants some, just not enough for me to get to it.
Happy HotRodding.
BTW
1) once the Idle-timing is set, you may have to revisit your PowerTiming and re-engineer the Timing curve. So do not run WOT until you get the PowerTiming back in line. If you later change your Idle-Timing, you will again have to re-engineer the PowerTiming. So then, again, you gotta get the Idle bugged out first.
2) And that means also, that the coolant temp has to remain rock-solid. You cannot tune the idle with the coolant temp wandering around. If you later change the minimum cooling system temp, you may have to fiddle with the Idle again, which may lead to changes in the Power-Timing..... again.
3) if your cooling fan is blasting air across your float-bowl vent, that is sure to cause trouble, do what you gotta do to stabilize the air-pressure in the float bowl.
4) if your intake manifold is too cold at idle, the Idle AFR will go lean as the fuel condenses on the floors. Then rich when it tears off and re-enters the airstream, then lean if the fuel particles are too big to catch fire in the allotted combustion time.... To help solve this, I run a coolant temp of 207*F in my AirGap equipped, alloy-headed, 11/1-367.. Yeah I know, everybody says I could get more power at 160; Ask me if I care, on account of she already goes 93 in the Eighth.
For a streeter, hi-rpm Power ain't everything. Nor is low-rpm torque everything. The most fun I have is in Second gear(manual trans), below 35mph. The rpm at 35 in mine is 3000 rpm. It takes torque here, to get the tires spinning in Second, with just a foot-stomp, then it's game-on; a lil left turn, a lil right turn, steering with the rear tires, a lil sliding here, a lil there, zip the tach up to 7000, then compression braking back to 35mph, reload, and take the next shot. Whoot-whoot! Then get outta town. lol.
Thanks all. AJ I dont want to remove AFB carb just yet. I have a kit for the Eddy 1405 on the way. I received the Eddy 9266 spacer/insulator. I will install spacer when 1405 is ready to install.
So I figured I would buy a new timing light. Nothing fancy. Didnt trust the pickup on the Penske.
So got it started(hard start again).
Timing at 30 BTC. Idle rpm 650.
Lowered timing to 15, adjusted rpm to 600.
Set idle to 2000 rpm, had approx 32*.
Blipped the throttle to 3200 rpm and got 35* approx.
All this done with va unhooked and hose to carb plugged.
Decent amount of condensation
Sorry, Ragtop, you are getting very bad advice.
[1] You DO NOT adjust carb first.
[2] You DO NOT set the WOT timing, & then let initial timing fall where it falls. [ Post #8 ]
[3] When you have been doing this for 40+ yrs you learn a lot, & also from other people.
[1] What you do first is find optimum idle timing, post #7. Idle mixture/speed setting just needs to be in the ball park to find most efficient timing. It should be obvious from the procedure in post #7, that since you are not touching the carb, only ign timing, that this procedure finds the most efficient idle timing for that combo, as shown by the rpm increase [ more hp ]. Once idle timing has been determined, the dist centri curve can be done if used.
[2] Once you have idle timing sorted, THEN you do carb adjusting such as T slot position.
[3] This link will explain MVA benefits & whole lot more about combustion; scroll down to post #6. If it does not load, type in manually.
www.hotrodders.com/forum/vacuum-advance-hooked-up-directly-manifold-bad-47495.html
Thanks for link, I had actually saved that the other night when I fired up the Googling machine but hadn't read it yet.
So reading that link, I can see reasons for both ported or manifold vac.
My AFB only has manifold vacuum. I wonder if that is part of the problem.
Eddy 1405 gets dirty from old fuel.
I replace with Carter 4295S I redid 4/5 years ago.
It only has manifold vac and the eddy was hooked to ported?
I just hooked up vacuum gauge I had to front port on AFB. 2"hg at idle(650 rpm)
Thanks.
To check vacuum, the hose needs to be attached to a port below the throttle blades.
Halfafish,
Post #16. Maybe you can help me out. I typed in exactly the same thing you did, but it not come out properly. What am I doing wrong?
Rag,
For MVA, the VA unit can be connected to ANY port or position below the t/blades, except the PCV line.
You can Tee into the brake booster line or any line that might operate off engine vacuum such as air vents, h'light doors, etc.
Probably the easiest is in post #17 pic. See the rubber tube on the left side of the pic, goes to choke pull off. You can tee into that.
Are you talking vacuum with big gauge(2nd pic above)?
There is only 1 port to connect to, that's above throttle shaft (1st pic above)
Steve that should be the ported vacuum. If you are getting Vacuum, there at Idle the throttle blades are a bit open. Also, to me 30 at idle is insane amount of initial when you add at least another 28 or so mechanical to it. then vac advance. Have a distributor number? Just for S&G check and see of you have a broken or MP spring in the distributor. Easiest check is to look down and see the springs, might have to rotate the dist. aka bump the engine and after that turn the rotor by hand and see how much resistance there is and if it will return by itself. Just spitballing here. If needed call me and we can go back and forth on the phone just easier.
Halfafish,
I have no idea what happened. I've seen that article before so I knew what it was. I just copied the info out of your post and dropped it into a link. Chalk it up to computer gremlins? :realcrazy:
Bewy, when I try to post a link I dont type it out. I "right click"( that should highlight the link, then copy and paste. Hope that helps?
Wont tying into choke pull off cause "issues" there?
Halfafish,
Rag,
Ray, I think this distributor is one I sent to you to redo? I dunno.
I realize that the port on AFB is ported vac. So is that where factory tied into for va?
I'll remove distributor and look a little closer.
Thanks all!
Yes that is the ported vac. Vacuum should be zero at idle and increase when the rpm's go up. Honestly I dont know if that is the one I sent you what color is the pad under the rotor? I use a different color just for this.
