Mopar
I know your past this but would a larger valve cut down with a 30 degree seat sitting on the current top cut height work (assuming .5 inch lift cam max)
only way I saw to save without seats
I'd have to have a 15-22 degree top top cut then narrow and open up the old 45 and the rest with the Serdi
2.08 valve , yes.
They are sunk .060 deep into the chamber with a ledge around it. Can they be saved? Do it all over again, new bigger valves, clever chamber side radius cut...How much you wanna spend? What is the number 1 goal?Then after that, the porting. Only if they were the last set of heads on earth would I even bother. They're a black hole in terms of time/money vs return.
Is there even enough meat in a 308 bowl to support a 2.055" unit???
How much effect on the combo do you want impose in order to make something work. He could probably fair swell with 1.94 intake valves with what he is doing and target #....so 2.05? Unfortunately.. the seat is sunk .060... then there is the valves head margin outside of that. You can see about .015-.020. gap around the valve head and surrounding chamber ...so maybe 2.08 would be perfect. Ay...yeye get what I'm saying?
You would spend twice to have what...?
To hell with playing mad scientist or machinist expert, nothing to prove...the guy already spent on these heads and they're fucked up. He would not be of sound mind to put another $400 + into these things. 2 shops have looked and said...no thanks, just get another set...they are not special.
Anyone traveling back east from the west coast ,near me, and could take these back to Randall, let me know... because paying the shipping isnt worth it. I want him to have them back so he can toss one through the window of the shop that ruined them.
I'd be pissed if I were him... though as soon as I laid eyes on them at the counter I would have put my wallet away and asked the guy for a new set of heads before I took him to court and had 3 other shops outside of town give written report of the heads even it cost me the tear down. The guy screwed him.
