MOPAROFFICIAL
Oogliboogli
Definitely a spectator I am.
Well....a little info to bring you in... one port is under the tall head bolt boss ... and the other is below the counter sunk head bolt boss.
177cc and 175cc-lower head bolt.
Still small, like 'ironbrocks'. lol
LOL I poured mine and didn't write it down.
I make a spacer to space up that bolt boss on the short bolt. That way I can grind the roofs all the same and the spacer fills in the hole where you break through.
I'll do the same thing on my W2 junk.
I'm in the process of doing just that for a set I'm working on. I think Mopar used to make a kit to do just this back in the day.
I do the hard washer in the bolt recess as well. These I want to be 'zero problems' or '100% reliable without a doubt' 'to last like OEM' for Randall. Not that the washers become an issue, just that this is not a max effort port job. We are about waist deep. 10 more cfm would be chest deep... and you gotta ask if you handle the disappointment if it hits a water jacket or head bolt..LOL I poured mine and didn't write it down.
I do that too. These heads are meant to be as reliable as OEM without a doubt, nothing special needed , and the last thing to blame if something fails.. lolI'm in the process of doing just that for a set I'm working on. I think Mopar used to make a kit to do just this back in the day.
I cc'd one chamber. 70cc
.070-.080 deep shallow side of the chambers
Yep, that's included in the head service. Figure out what they are after the valve job then mill to desired cc.Did the machine shop mill the heads to flatten them?
Okay..paid the machine shop a visit to square up , will be posting the #s int/exh. In the meantime some crank grinding action going on over there.
Will post some more.Sure look a lot better than the 308 sunk valve heads I shipped you.
These heads are using the same 11/32 2.02-1.60 SS Edelbrock valves also.
I think they should work great with my .508 cam in my .060 over 340.
Post some finished pictures.
Btw that last pic IS a finished port.
For those watching...I did initial port work, sent them off for a valve job, did not approve of said valve job...testing even showed...so i took them to my other guy who did it right. Tested them again with big improvements to all but with some needing attention with air speed issues. I widened up the area between the guide and head bolt some more on those with the low head bolt pad and thinned the push rod hole a lil more, which did help. I also exploited the cast in swail just a hair, to help speed the common wall side of the turn, equalize the middle more..as well as a angled lip where the turn comes off the common wall. Hard to explain and odd sounding I'm sure.
Just edit yours here and take it to your thread.Sorry !! Mixed our threads. No meaning hijacking
