Yes I did. Again, she revealed nothing.Have you looked for a build sheet under the rear seat?
So vin tag for this year cant be matched to a fender tag? That's pretty messed up. Like you said earlier throw the fendertag in toolbox.
The vin looks hokey tho.
The two numbers can be matched with a Broadcast sheet or the IBM card, which I believe you can still get from Chrysler.
I wanted to match the body to the fender tag...
They don't. My Car was never a /6 car.
I've determined that it is in fact someone's tag job.
Well I stand corrected on how the VIN tag numbers were stamped. I went out to the garage and checked. Both my 65 Barracuda and my 63 Valiant are stamped the same way as the OP's and the two tags posted just above - that is, the first two numbers are stamped with a different tool and a different font. Guess I'm just gonna have to quit relying on memory and double check everything before I post.
My take on this is it was more than likely a V8 car with no title so they put the fender tag and riveted a VIN tag from a \6 car they had a title for. I would almost bet if you drill the rivet heads off the VIN tag it would fall off.
That does not mean your V8 car is stolen it just means somewhere along the line someone did not have a title for it so they took the easy route and swapped what they had to it.
I would think the easiest way to check if this is true clean the end of the torsion bars and get those numbers. If they come back to factory V8 bars then it is probably a tag swap because just a driveline swap guys dont change the bars and usually leave the \6 bars in.
Yes the silver tag welded to the A pillar is a VIN tag but they have no VIN tag anywhere else on the body.There is no vin tag on any 1965 car... just a serial number. That's what is on the door post.
VIN numbers came a few years later. They show all the car info...country of origin, eng/trans info, etc.
Just a heads up....
Those bars must have been put in after the factory. The early cars never had a 383 option.Agree in most cases. But my 65 Cuda has A body 383 Auto bars. And 5 leaf's on both sides in the rear. I do not know if the two people that owned it after my mom sold it till I bought it back in 1987 would have changed them.
This explains it better with better VIN tag pics http://www.1962to1965mopar.ornocar.org/ml-staudinger64.htmlThere is no vin tag on any 1965 car... just a serial number. That's what is on the door post.
Just a heads up....
No its not...its a serial number. Plain and simple. Show me where it tells you the country of origin, the original engine, transmission. The last six digits of a VIN number is at the back of a 13 digit VIN tag. That part is the old sequence number.Yes the silver tag welded to the A pillar is a VIN tag but they have no VIN tag anywhere else on the body.
Again here is a link for you to see it is a VIN on the tag in the door jamb. The sequence number is on the fender tag under the hood and does not match the VIN number on the tag.No its not...its a serial number. Plain and simple. Show me where it tells you the country of origin, the original engine, transmission. The last six digits of a VIN number is at the back of a 13 digit VIN tag. That part is the old sequence number.
Words have meanings...you cant wish a '65 to have a VIN number... Just like '54 and earlier cars had " engine numbers" and had that number on the titles or registration.
Also 54 and earlier had a VIN tag that was not the engine number to that vehicle. Trust me I have owned several early cars and had to have a title corrected on a 1941 Chrysler to read the VIN number from the attached VIN tag.No its not...its a serial number. Plain and simple. Show me where it tells you the country of origin, the original engine, transmission. The last six digits of a VIN number is at the back of a 13 digit VIN tag. That part is the old sequence number.
That is what happened to the 1941 I mentioned. They used the body number instead.I just went out to check my 49 Dodge. There is a "body number" on a plate attached to the firewall, but the "Vehicle Number" is on a plate attached to the drivers' side door jamb. This number is the "Identification Number" on my title.
I do have a vague memory that way back, some states used the engine number as the vehicle identification number, but I don't think any of them have done that in the past 75 years or so.
