Based on that post my 7.342 length is correct
so in your opinion this valve train is *also* a mess because of the pushrod angles?I've seen plenty, that valve train is a mess
My research of those pushrods said they were longer but if that is what they are you may be just fine.Based on that post my 7.342 length is correct
Those look good. Somebody else made comments about those pushrods on the op 340so in your opinion this valve train is *also* a mess because of the pushrod angles?
Here is everything cleaned up i also backed out cylinder head bolts and retorqued them the proper way in case they were not right as well… as far as cam journals and cam and crank and crank journals i have to just assume they are all right and cross my fingers.
There are grooves on back side of shaftIf there aren’t grooves in that shaft do NOT put them back on without putting grooves in them.
If the shafts aren’t killed already they will be. You absolutely, positively can not run those rockers with hydraulic lifters and no grooves.
That shaft looks like it got hot and lacked oil.
You've got to set it up and measure to get the right ones. Many factors to take into consideration.Does anyone know what pushrods i need? That could of been a problem
You'd think that.....I put together a 340 and was planning on using the 273 stuff. After I was done measuring I needed pushrods approx. 7.1 inches long. Smith brothers was 4 weeks out so I just used the oem stamped stuff.Based on that post my 7.342 length is correct
they do look a little galled up. hopefully that's just the photo... but with the glimpse of the cam in that other shot... i dunno man.That shaft looks like it got hot and lacked oil.
Looks like scrap to me.
Find out exactly what you HAVE first, before you pull the trigger on anything.
A little off topic here.......While I am thinking about it...
The WP bolts look new? You know about the driver side shallow timing cover hole correct? Too long of a bolt there and it goes through #1 cylinder. I believe it is the 2nd from the bottom IIRC.
Can you catch any of those scores with a thumbnail? I don't think it'd hurt a thing to polish them up with some emery cloth and mineral spirits.
That's what I would do......$4500 for the engine PLUS a six pack.......Good call Troy, man this sucks but I suggest a complete inspection piece by piece.
Yeah i will clean those up a bitCan you catch any of those scores with a thumbnail? I don't think it'd hurt a thing to polish them up with some emery cloth and mineral spirits.
.........And pop the end caps and clean them out.Can you catch any of those scores with a thumbnail? I don't think it'd hurt a thing to polish them up with some emery cloth and mineral spirits.
