Is this engine recoverable?
I have a V8 I'm scrapping!
How much do want to spend on it? This will be a very expensive rebuild.
Looks like 800 in machine work and maybe 200-260 in parts.
Usually a slant is around a 1200 dollar motor to rebuild ,figuring some new exhaust valves.
Do I really need cylinder 1 though?
Not sure? Cylinder 6 is usually the 1st one to go flat being the farthest from the radiator. You could have a dead hole on each end, it might balance out???
It was never final honed, I have 2 or 3 thou... I'm gonna build it, and plant it, or put it out there. Steel crank HP box truck unit Big rods.
