mopar head
That`s cause they always leak there.
Regarding the overtightened carb bolts?use they always leak there.
As bad as it looks, the motor isn't stuck fortunately. The block casting # is 63-66, so that's likely original. The head has some remnants of blue paint, so likely replaced at some point. Someone put some work into this thing (brake and rear end upgrade) long ago before it was left to rot under some trees in Eastern Tennessee. The master cylinder is crusty externally, but when I popped the lid its dry as a bone and still looks parts store new inside.Nice
Thanks, I realize the choke assembly is available online with the rod but I wasn't sure about the bracket on the choke shaft on my carburetor.Rock Auto is your friend
I'm pretty sure that connects to a rod that goes to a thermostatic choke control. Basically a brass coil spring under a cover that pull the choke closed cold and as it heats up it opens and relieves tension on the spring. You can see the silver cover and rod in this picture.The carburetor is rebuilt. What am I missing on this BBS from the choke assembly?
I've seen some photos (as well as graphics in the rebuild kit) of a triangular bracket attached to the shaft with a spring, but that bracket is different than what's on this particular carburetor.
I appreciate it! I'm tracking that, I just thought I might be missing something on the carburetor end. I'm good to go, over thinking it.I'm pretty sure that connects to a rod that goes to a thermostatic choke control. Basically a brass coil spring under a cover that pull the choke closed cold and as it heats up it opens and relieves tension on the spring. You can see the silver cover and rod in this picture.
Maybe they had aspirations of drag racing, haha. The guy had a straight axle front end he was trying to get me to take home, too.Interesting that someone apparently had been drag-racing that slant (based on wheels & tires) before parking it long ago. Looks like typical rust for AL, and even some cars in CA.
If you've never tried EvapoRust, it is great though pricey. You might need 2 jugs and a plastic container just the right size for the LCA. Scrape off as much rust as you can so the EvapoRust lasts longer. You might follow with a dip in phosphoric acid ("Concrete Etch & Metal Prep" at Home Depot) to convert any remaining rust in pits to black iron phosphate. A member in Sacramento occasionally sells restored Mopar suspension and brake parts and uses EvapoRust.Maybe they had aspirations of drag racing, haha. The guy had a straight axle front end he was trying to get me to take home, too.
I really need to adjust the torsion bars back down, I'm not ready to fight the rusty lower control arms yet though.
