Longgone
John/68 Barracuda & Dart
With 3.91's you better buy some more tires!
:headbang: Been there..........done that. Dave, you will love the five speed!!!:thumbup:
Well, I got a chance to talk to Richard at Keisler again and he told me that yes you do have to cut the rear crossmember on the a-bodies. The directions are not very clear on this at all. IMHO. He did inform me that the Keisler tranny mount was over engineered in order to stregthen the cutout rear crossmember. He is a super guy to talk to and is very helpful. This was helpful information that I wish I would have known beforehand. I may not have been so upset about cutting the rear torsion bar crossmember.
Anyways, my drive shaft should be arriving tomorrow so I may pull the old rear and get things started on the rear this weekend.
Word of warning>>>>>you do have to cut significantly for this project but it can be done. Good thing I have lots of patience.
On my `68 Barracuda I didn`t have to cut the crossmember(maybe because it`s the next generation) but I did have to bend the top cover plates to give me clearance. The cover plate is one thing that Keisler really needs to re-engineer. The thin little stamped top plate they`re using(it`s bent 3 ways) is quite inferior compared to the rest of the trans. A good cast cover would be much nicer and cut down on the RTV needed to seal everything. Just another opinion.................and you know what they say about opinions. Lol! Bottom line is I LOVE what the Tremec trans has done for my car. It`s the best mod I ever made to it!!!
Im willing to cut, no problem there. I beat out two grooves so that my valve cover on the passengerside would clear (5.7 hemi is wide). Did you get the kit with the drive shaft?
dave; from the pics i have seen,,that tranny cross member is not over engineered,,and wil not make up for what you have cut out,,he is handing you a lot of crap,,its good that you didnt cut that top hoop out completly,, from seeing what you have done,,when i get that far i wil reinforce the hoop some how,, either put a piece of flat stock back in,,or remove it completly and reshape some thing,,,even tho i do not have torsion bars any longer,,
the part that didnt clear that top hoop part,,,is it a spot on the trany that can be milled off like the other spot milled and covered ???
glad you got your car back,and your under construction,,cant wait to se if finished,,,,
if you can i would put a piece in there,,,just my 2 cents no harm intended,,,
DAVE great job as usuall,,any chance u can show what part of the tranny hit that piece you had to cut out,?? and did you have that problem in the trial car????
DAVE do you think the tranny case could be installed with out mods,, if you modified the torsion bar cross member??
dave nice pic thanks,, i have not contacted tremec yet,, but i did talk with them last year on the power tour,,,
im guessing the area of concern is the plate that surrounds the shifter and the first big square plate forward of the shifter,, what shifter are you using? cant wait to see your shifter thru the floor to see if its ok in the middle of the tunnel verses off to the side like factory,,
Hey Dave, it's looking good. Say, you going to FallFling?
