Swingin Chrome
Thank youHappy birthday to you also swingin chrome !
Thanks Fred.RJYes swinging chrome hope your birthday is a good one.
Sorry to see that and of course hard to find.Think I got a little water issue
You have a septic tank ?
Yes sir, what gave it away?You have a septic tank ?
Not a thing just puzzled about the inch and a half line beside the main. Look like ground water coming around the patch. Does the water smell like sewage?Yes sir, what gave it away?
Good I’ve seen the fibreglass ones float after they’ve been pumped and a heavy rain comes. If the pipes are ok what I would try would be stone veneer mortar You can get it at most lumber yards it has an epoxy type glue in it. Chip out as much as you can use air compressor to blow all loose concrete and dust if concrete is damp good if it is bone dry squirt a little water on it. Then mix according to instructions on bag and forcefully Chuck, throw it in to the area, then with a small pointing trowel smear it to all sides scraping mashing it into existing concrete to form bond. Depending on how wide and deep the hole is you might have to make two or three applications repeating the method each time. Should work.It's probably been a year or so
And the rain hasn't been too bad here
I appreciate the instructions, but im going to let a professional handle this oneGood I’ve seen the fibreglass ones float after they’ve been pumped and a heavy rain comes. If the pipes are ok what I would try would be stone veneer mortar You can get it at most lumber yards it has an epoxy type glue in it. Chip out as much as you can use air compressor to blow all loose concrete and dust if concrete is damp good if it is bone dry squirt a little water on it. Then mix according to instructions on bag and forcefully Chuck, throw it in to the area, then with a small pointing trowel smear it to all sides scraping mashing it into existing concrete to form bond. Depending on how wide and deep the hole is you might have to make two or three applications repeating the method each time. Should work.
Sometimes the professionals do **** work and would rather do it myself but that's just me.I appreciate the instructions, but im going to let a professional handle this one
I'm sure your right l, but I got a few guys I trustSometimes the professionals do **** work and would rather do it myself but that's just me.
No problem the best thing about hiring someone is you have someone to complain to if it doesn’t work.I appreciate the instructions, but im going to let a professional handle this one
So I went out to the garage around 10:30 this morning, after thinking about the coolant leak since about 4:30. Started taking it apart, and quickly found that I had pinched a small coolant hose that runs to the throttle body, and that was where the leak was originating. Replaced that section of hose, reassembled everything, and finished putting it back together. Got it running, has a small exhaust leak, tried to fix that, but have never had much luck with exhaust, and my temperature and oil pressure gauges aren't working, something else to fix. I also had to change the radiator, I apparently damaged it when i took the old motor out, but fortunately I had a spare one. Back to work tomorrow.Well I should be done by now, and I would be except that there seems to be a coolant leak at the back of the engine. Looks like it's coming from the intake manifold, so not happy about that, done for today, will think about it tomorrow when I get up, time for a few cold brews. **** it!
