LCA Bushings and Other Bushings
That is why I'm probably going to go with the Delrin bushings and pins that you have. It seems like it would be much easier that way
Keep in mind, the nut will tighten just fine with the suspension loaded and an air gun. For anyone considering this upgrade, delrin is a far superior material for this application. When using my pivots, the inner and outer shells are eliminated.
Lower Control Arm Pivots - Mopar - A Body - Bergman Auto Craft
BAC Delrin Lower Control Arm Bushings - Bergman Auto Craft
So sell me on it. What's superior about delrin? Why aren't your pins greaseable? Does delrin not need grease? I get the strength thing. How so you eliminate the inner and outer shells? Through pin and bushing diameter? The bare bushing just presses into the control arm?
Delrin is considered a self lubricating material. Grease during assembly is all that’s needed. It’s hardness prevents noise unlike urethane that’s softer.
My pins aren’t drilled as that weakens the pin and as mentioned, greasing isn’t necessary after assembly. My pins are the same Rockwell hardness as the originals. The pin is sized for the ID of the bushing already. This provides a round surface for the bushing to ride on. Same with removing the outer shell from the arm. A round surface is left for the bushing to fit into.
View attachment 1715738799 View attachment 1715738800
This is for drag racing only, totally not not needed on street. Top uca bolts can move out of alignment, just look what holds the stock bushing, a thin ‘ring’. designed to move a little
That is the best set up I have seen yet. You could market that. I can wait to show my son that. Great for easy travel for a race car and will hold the arm against the K-member. Nice to see someone on here with a great idea. This could be expanded on very easy for street use. Much better then the slip and slide poly bushings.
The precision fit of my pins and delrins, along with the expansion rate of delrin, prevents this from happening, provided the strut rod is adjusted properly.
Ceedawgs attachments are the only pictures I have seen on this site that ever made any sense. Looks like he is the only member that has a understanding on how things actually were designed to work.
That poly material squeezed out of the bottom is the poly material being squeezed so much that it’s forcing the poly material into play dough. It’s squishing out the back
when you installed your LCA by itself, does the LCA move up and down freely? With the LCA off the car, can you rotate the pin a little? Should rotate, but be tight
When I installed my poly LCA I shaved them down to fit the LCA hole. And I sanded and polished the hole with porting scrolls. Removing any burrs that could keep the LCA from freely going up and down.
I also polished the pins that you leave the old rubber metal sleeve on.
I installed these in 1997 by hand, no press. They went in hard, I used a block of wood to help.
We removed them in 2010 at Hotchkis to install their kit. They said (and I saw) they still looked good and we re-installed them.
* btw the pin in the middle below will not accept a poly bushing *
Because there are a couple ways to solve the perceived "problem". If this offends you in any way, happy to delete.
Your not offending me at all. Having a machine shop we tried it all Bronze Aluminum and several other materials. Unless you attach the LCA to the pin as Ceedawg shows. That arm moves off the pin.
The only reason for eliminating the OEM bushing would be for ease of travel up and down for weight transfer. There are many after market suspensions out there designed to do this . We were going to go with HDK. But bought a project car with an AJE suspension. If we had to do it over we would have went with struts for a race car due to no upper arms. I would recommend HDK for a multipurpose car. SW race cars sells AJE. They are basically designed for light weight No steering box and no torsion bars . AJE K-member is not the strongest
OK I thought that might be the case. I have used model railroad gears for locomotives in the past made from delrin. Must be the same stuff, because in the instructions, it said no grease.
Ok, so "what if" I buy your high dollar nice stuff and have issues with the LCA moving around? Even with high dollar adjustable strut rods I plan to get? Where would we go from THERE?
To each his own. I'm not a drag racer, so that's not my focus. However, my experience shows the arm does not move off the pin when using my pins/bushings. The fit is a slight interference and the delrin expands a bit when warm. Combine that with an adjustable strut rod, I haven't seen any issues. Like I mentioned earlier, instead of reinventing the wheel, push the t bar all the way forward and put a set screw in the socket if its a concern. It's a simple solution.
Was this my answer? I hope not.
How can anyone install poly LCA bushings wrong. You push them into the sleeves and then push the pin in. Oh yeah don't forget to lube them up with that special lube so they can go in and out real easy.
The strut rod bushings only go on one way. To destroy them you need Horse power. Apply the brakes real hard and do a burn out with big tires. 12 -15 inch wide Hoosiers . Racing on the street you don't always get to use water to heat the tires. Mine never lasted after some good foot brake races. They squashed apart just like if I would put them in a large vice in the shop.
We don't drive like old ladies here. We abuse everything.
The torsion bar does not hold the inside of the lower control arm front. The OEM sleeved rubber bushing does until its ripped and then there shot. Age or tightening the LCA nut without the car on the ground does ruin OEM bushings.
I just had a Challenger here that had poly bushings Had the customer watch as I backed it up and hit the brakes hard. The control arm backed off the pin at least 1/2 inch and stayed there until going forward. Try this for your self.
I don't know why I bother, but what the heck.
Yes, you can improperly install poly bushings. The "slap them in and slap the pins in" mentality is exactly why people have problems with them. Because the original style of poly bushings reuse the factory bushing shell, the fit between the bushing and the shell has to be checked and it has to be right. It should be a tight slip fit, like autoxcuda shows in his post. The same is true if you re-use the factory pin and inner shell, it has to fit properly. The factory shells are not all the same dimensions, when I installed my Delrin LCA bushings I measured 4 different sets of factory pins with their inner shells still in place and got 4 different numbers. All were close, but they were more than enough to alter the slip fit on the bushing. If the poly bushing is loose in the outer shell, or the pin is loose in the bushing, you have to correct that fit. If you don't, they will fail- and that's improper installation.
The strut rod maintains the track of the LCA. If you use the factory strut rods and bushings, the large rubber bushings will allow the LCA to move around. They do that with the OE LCA bushings too, btw, it's just flex instead of slip. The torsion bar may ultimately stop the LCA from falling off, but it would allow it to move entirely too far to maintain an alignment.
I don't need to "try this for myself", I do it everyday. As I have explained a hundred times, I daily drive my cars with these bushings that you couldn't make one pass down the track with. I run 275mm wide FRONT tires on them. That also means I have almost no extra clearance to the fenders. If my tires moved back and forth a 1/2" every time I stepped on the brakes, I would have destroyed my tires AND my fenders on two different cars. Nevermind that a 1/2" movement at the lower ball joint would result in a MASSIVE change in the caster angle, making the car straight up scary on the street. Properly installed poly bushings, with proper length strut rods, do not allow the kind of movement you describe. If they did, I couldn't drive my car everyday. It would not hold an alignment, and it does just fine.
I don't know why your car did what it did, or why your customer's Challenger did. But I can assure you that properly installed poly bushings, used with the proper length strut rods, don't do that.
I make precision fit pins and delrin bushings. I purposely did not gun drill them for grease as I didn’t want to weaken the pin. A majority of the suspension load is on the lower arm, so this isn’t a place to experiment. I’ve even gone as far as Rockwell testing the originals and using the same material. This ensures safety in an impact causing the pin to bend not break. The material is more expensive to do this.
I’ve also made sure there is a degree of interference fit to compensate for temperature changes and break in wear. Delrin lasts longer than any Indian or Chinese rubber bushing and offers precision movement. I’ve installed many sets besides selling them and never experienced vibration in the steering wheel. Pushing the t bars all they way forward and drilling the socket for a set screw may satisfy some of people’s concerns. This is one mod that’s a nice upgrade from all the low quality rubber parts on the market. However, I respect the fact that upgraded handling is not everyone’s goal.
Gun drilling a small hole for grease does almost nothing to weaken the pin. With the proper materials, the grease hole is not a structural issue. I've used Firm Feel's greaseable LCA pins for tens of thousands of miles on both my Challenger and my Duster, both with 275mm front tires and 1.12" torsion bars. Those pivot pins failing is the least of my concerns.
I'm glad you're making your own LCA pins now, because the 3rd party ones you recommended I buy for your Delrin LCA bushings didn't fit properly at all, they rattled around in the bushing. The Firm Feel pins fit perfectly, even if I don't ever need to re-grease the Delrin.
I know this is an old post but I thought I would chime in on my recent experience installing the greaseable LCA poly kit available through PST. First off MOPAR's torsion bar suspension is a joy to work with as far as breaking down and reassembly. The most challenging step dealing with the LCA bushing is by far is the removal of the inner sleeve of the LCA bushing assembly. It is NOT as easy as everyone is saying it is. You will see all kinds of videos on this topic including welding a washer to the top in order to press it out from the back. This was a struggle for me and I ended up using a torch and chisel to drive it out. This approach worked well for me.
When installing the new poly bushing assembly you need to press in the sleeve provided FIRST! Do not attempt to press the poly bushing into the provided sleeve and then press in the LCA. You will end up with something like this. The top of the poly bushing will not retain its shape. I had to heat it up to get it somewhat where it was originally. Ended up purchasing another bushing. The shaft and inner sleeve where not damaged.
Once the poly bushing is installed you will notice the mushroomed top will NOT seat on top of the new sleeve.
You will also notice if you press the pin in with an extra pump on the press you will end up with some of the end of the poly bushing undermining the pin. So make sure you stop once the pin is fully seated. It doesn't seem to effect anything.
Now when installing the LCA in the K-Frame I had an issue with the pin turning in the bushing when using the nut provided. I had to purchase another nut and lock washer. You can't tighten the pivot shaft nut without the shaft itself turning. I did not expect this but it is a greaseable assembly. I will attempt to torque the nut after I lower the front end. The dimples on the nut catch the threads as they should however this makes the pivot shaft turn.
Here is the installed LCA. You can see the stop of the pivot shaft against the K-Frame.
View attachment 1715739012 View attachment 1715739013 View attachment 1715739014
Should there be a concern that the only thing really keeping the LCA in place is the strut rod and the clip behind the torsion bar? We shall see.
The easiest way to remove the inner shells is with a large tap...
And I do not like that extra poly material pushed out around the pin. The whole point of the poly is that it should rotate smoothly on the pivot pin. I very much doubt those will do that.
Exactly. The bushings and pins should be a tight slip fit. Another street and road course driven car that hasn't had any issues with poly LCA bushings. It's almost like the LCA sliding off the back of the pivot pins with poly bushings is total hogwash.
This I do know. Before I actually used Poly bushing I had several emails with 72nublu to make sure I was understanding what he is saying.
Then I used the poly bushings and QA1 adjustable struts rods. It is physically impossible for the LCA to move on the pin, let alone slide off of it or even partially off of it. IMPOSSIBLE. A foot brake car can’t force the LCA a off the pin, nor can a trans brake car. It’s IMPOSSIBLE for the LCA to move if the strut rod is on the LCA and frame and correctly adjusted. The LCA can not move unless the strut rod stretches, and that would be impossible.
I can say that at this point no matter what bushing I use it will always get adjustable strut rods. They are relatively inexpensive and they are so far superior to the OE units it’s not even close.
Yall keep talking about "if the strut rods are adjusted correctly". Exactly WHAT do you call "correct" adjustment? I'm curious, because I plan on using the adjustable QA1 strut rods. Thanks.
Last time I checked the adjustable strut with the swivel holds less then the solid strut for movement at the K-member. You all can use what ever your happy with. There are applications where a those bushings are good to use not on a mopar LCA . And who ever drills that pin to lube it good luck. Why would you have to lube that bushing if it don't move on the pin. LMFAO. Just like the OEM strut bushings with the shear sleeve that you all said were NA . Just bought another set.
Thanks again for the input. I will install new bushings so I can sleep better at night. And yes they were both a tight slip fit, however I should not have cranked down on my press. I am thankful for this forum!
Awhile back we were not allowed to use the QA1 strut rods but they allow them now. I’ll be looking into that.
Just a thought, why not add another rod to the front of the strut (at k-frame) then back to the lca close to the pivot, triangulated, arm would never move either way then.
