What are everyone's thoughts on this 435 kit from Hughes.
Yep, quoted below.Did I say it's cause of stroke length, not it's ability to breath with similar top ends.
I see where you’re going with this and it would be accurate if all the same parts are moved over from a smaller engine. A 340 for example will want to move more air at a higher rpm than a 408 or 434. At the smaller CID and W/the shorter stroke, it will need to turn more RPM’s where it will make the power. The larger 408/434 will need less RPM to move the same volume of air and fuel to make the same HP.I see displacement more as a powerband selecter,
What ever floats his boat….He seems pretty stuck on his head choice. Which is fine as it’s his build.
I'm not doing any FAST racing, but that is the theme I'm going for.
Brian I am glad you chimed in. I was hoping to get your thoughts on what would need to be done to a set of J heads at this performance level?Nothing wrong with more stroke in a street car with tall gears!
Brian would be the man to help you get that engine combo matched up optimizedBrian I am glad you chimed in. I was hoping to get your thoughts on what would need to be done to a set of J heads at this performance level?
How far do you plan on modding the J heads ?Brian I am glad you chimed in. I was hoping to get your thoughts on what would need to be done to a set of J heads at this performance level?
I think I would just have kg engines do the whole deal if they're doing the CNC work. Makes no sense to send them to another party after that.My suggestion is talk to KG engines in Ohio. They have a very decent cnc program for J heads that is very reasonably priced. Then send them to Porter Racing for the finishing touches and cam suggestion.
Eehh... I don't know how to say it a better way, but my experience and a couple others has been his cnc program is awesome, but his finish work left some on the table. Dwayne has his hands in most of the FAST builds and is a huge wealth of knowledge getting these combos working. Mine included.I think I would just have kg engines do the whole deal if they're doing the CNC work. Makes no sense to send them to another party after that.
Bronze guides, good machine work, porting to get about 275cfm (to keep it cost effective) and good valves/springs.Brian I am glad you chimed in. I was hoping to get your thoughts on what would need to be done to a set of J heads at this performance level?
Like I said before, I’m just throwing out ideas. If I’m paying for a stroker kit anyway, why not pay for another 19 cubic inches?
I’ma small block guy and I’m gonna stay that way. I’m not sure what you mean by “true colors kinda guy” but I have been a Mopar guy for almost fifty years now.
To be a real purist, why even stroke it.Like I said before, I’m just throwing out ideas. If I’m paying for a stroker kit anyway, why not pay for another 19 cubic inches?
This should be a low 12 second car and budget is not a concern. I've built a 500hp stroker before and I know the costs.How deep into the 12's do you want to be and what's the budget?
