Major red X timeTrying to make a 318 fast is a total waste of time. What a boat anchor. If you wanna go fast with a small block the 340 is the only way. They rev way better too.
Now is when we need that X.Major red X time
Yeah yeah yeah, I heard that about the 383. lol Funny thing is the 383 puts out 425ft lb torque and the 340 only 340 ft lb ,both at 3200 rpm.
Major red X time
Trollin, trollin trollin
It will never end, just like the millions of other things that get debated to deathAnd the debate continues...........
That would be a short stroke.I want to build a 273. Out of a really destroked 340. That would be neato.
4.070 bore and 2.625 stroke.That would be a short stroke.
2.66 and probably needed longer rods like 6.46That would be a short stroke.
3.99", It won't be able to make power not 4" +4.070 bore and 2.625 stroke.
I'd really need to juggle the bore and stroke around so I could have a *2.73"* stroke 273
Ohh yeah! I bet with those super long rods it's just bound to be a real screamer!2.66 and probably needed longer rods like 6.46
It's just a fact that anything under 339 cid you can't make power with.... well.. cept the 20million 5.0 mustangs that did itSmfh. I want the ten minutes of my life spent reading this thread back.
No wonder teenagers give up and put fart pipes on hondas instead of building musclecars.
Some of you guys just suck the fun right out of it.
But the 5.0 comes with the magic 4" boreIt's just a fact that anything under 339 cid you can't make power with.... well.. cept the 20million 5.0 mustangs that did it
That's not true. In order to keep the peace all I'm going to say is read on what 318willrun did with the 318.It's just a fact that anything under 339 cid you can't make power with.... well.. cept the 20million 5.0 mustangs that did it
But yet, look at how many recommend a 360 and like the Teen, came with 2 barrel carbs. The 360's were a workhorse engine like the 318. Not meant to be a performance engine. The 360's got modified because of their Cu In. size.A lot of people have a problem with seeing past if the factory ever offered a performance version, if not the answer to them then is it can't be made to perform.
That is exactly the comparison I always think of any time a 318 build is mentioned.It's just a fact that anything under 339 cid you can't make power with.... well.. cept the 20million 5.0 mustangs that did it
360 did come with some of the 340 goodies, but took a lot of time before it became the preferred starting place, 340 were the go to for the longest time.But yet, look at how many recommend a 360 and like the Teen came with 2 barrel carbs. The 360's were a workhorse engine like the 318. Not meant to be a performance engine. They got modified because of their Cu In. size.
