She's fired up and running. Had some trouble sealing up the rear main seal. Pulled the pan along with the main seal bridge and #5 main cap. Took .006 off of the end of the bridge and installed a new main seal and side seals from Dan Dvorak. She's sealed up now, no leaks. Still trying to figure out why my electric fuel pump is not pumping fuel to the carburetor. She sounds good. Oil pressure is good. New Cold Case radiator cools great. Have all the factory gauges working along with the new Autometer ones. All the lights turn signals side marker etc working so new wiring harnesses went in with no trouble.
