j par
Well-hung Member
Mark the calendar! For a bodies only members with no opinions? LOL
Just putting my Stock hood back on. I bought a spare Hood to do this On for 40 bucks but actually it's in better condition than my Stock hood LOL so I'm just using my stock one. That's another thing I need to calculate probably as how it's going to collapse Down On It from the correct direction? and have enough height to clear my velocity Stacks as it comes over? And not having to take the cleaners off every time I open or close the hood!Lift off hood or hinges?
With the lift off you can fit the hole right to the carbs, manifold. With hinges it'
Gonna be a big hole to allow for the hood to swing up.
Agreed totally! So now if you're looking at that side view and I was actually cut it where that blue tape is which is perpendicular with the hood. It would drop 3 in correct? And now both it and the hood drop 3 in. Correct? I believe I have about six and a half inch from the top of that back pentastar which would be the top of the air filter to the inside top of that plastic as it sits on those glove boxes. Something to throw in the calculation I've always had the back air filter on a little 3/4 or 1 inch riser to kind of have its own little bit of fresh air it gets. So I could drop that down level with the front one and get more room back there but not much maybe another inch or so. Which would help lower the scoop a little bit. Or I could just get lower air filters and or lower those more to lower the scoop. But honestly I'm with you and don't want to be locked into no scoop I just really want a hole in the hood and it's quite funny that a 14 inch wide by 20 inch long hole is just about perfect for what I need and maybe I could just put this on and play with it a little bit once in awhile. Good chance I might think it's totally stupid and still never use it.Know it's your car and not mine but I still say no scoop.
If you are gonna run that scoop I think it needs to come down a out 4 more inches.
You want the top of the scoop about an inch off the top of the stacks. IMO.
Who still has a bread box? I've personally never seen one, but then again, I'm only 39 years old.
Like they say Size Doesn't Matter.
Cut that hole as big as you want.
Post 270 may have a small fib in it.
We do. and from J's reply I'm pretty close to the look he's shooting for. 39, that explains a lot. lol
Cut the thing, its just a spare hood.
Well your close...Looks good like it is.
Now show how big your garbanzos are and paint the hood gold.
When you are under 40, you can do cool stuff like that. At your age...maybe not...................
Well you know I'm just a hobbyist and Edelbrocks are better for us hobbyist. It took very little time learn how to tune one LOL. I know if I wanted a Max effort I would definitely get some Hollies but for the street and a little Hobby Action at the track that'll be just fine. The front one came with the car and the back one was a free one given to me as scrap metal by a Chevy guy who couldn't get the choke to work LOL. It's part of the Mystique of a car called "The Scrapper!" I like making on junk go fast LOLNow you just gotta throw those carbs in the dumpster and pick up two 450 CFM Holley.
Buy two of the HVH super sucker 2 inch spacers and be done!
then let all that awsome stick out in the wind.
When you're swinging a big hammer you don't hide it in the bag....
