j par
Well-hung Member
Aerodynamics for sure...?
Next one color..
Next one color..
It's been a few hours just sanding it by hand...That's some good metal prep.
What are you using?
I'm gonna go out of my comfort zone here and say, I dont like the open look.
Skin it with 030-020 aluminum & one million pop rivets to attach it.
No issues with dissimilar metals touching and light as a pop corn fart.
Or better than pop rivets, use aircraft rivets. Much cleaner on the underside (and top) but kinda a PITA to install.
Man you need to move to Ca, or better yet I should just move to your neck of the woods.
I could have that done and bad *** in a day.
I would think of doing that kind of with a stock skin? The aluminum conforms to the 73 and up bulge duster Hood..Its probably just cuz I work with aluminum and your car is currently bare metal but I'm into the idea of making you a hood skin.
I could do a huge DODGE on the hood of your Plymouth....
Or the direct connection arrow pointed at the stacks or to the beak with a trim ring around the stack opening.
Think it over, I think it would look bad ***.
And you know I'd only charge you double our shop rate plus some extra for all the time I've talked to ya.
Thanks again man.
410...I could do a nice big call out on the hood.
318, 360?
Didn't you have a call out before?
Just make a paper pattern, trace out the ribs on the bottom so I can plan around the rivets and I will make you a bad *** hood.
What ever you want, I can make it.
I have a hard time envisioning what you want.
Is that a three peice hood? ( 2 sections would be easy and cheep. 3 gets harder. I have to hide the sections.)
When the letters cross sections it's hard to make them line up perfectly if I'm not installing it.
What's on the driver side?
Large print is WAY easier to make look good on the roller.
That's totally cool! I was thinking something like that when I was talking about opening up the back two thirds..Just picking up from Jpar's and Cope's ideas.... cover the frame in aluminum, do a partial cut out, rivet the hell out of it and do your favourite call out.
I was thinking that also, but I was also thinking that that may be a lot of weight on the tip as the aluminum subframe is very flimsy..Thanks Jpar... maybe you can go Frankenstein all the way and recover the nose part from the original hood...
just thinking out loud...
Like mentioned, IF you have the frame in aluminum, the answer is a aluminum skin!!!!!! Then a logial scoop.
with spirited driving-wife VERY not happy
Dang that is pretty impressive considering it has been detuned for the reconfiguration! Good job!Well I guess I should post up a time slip ..
I didn't give a hard launch, it was perfect for a first test run. No one in the next lane, first few passes and race traffic still a little slow coming in. I felt it was a nice first pass, I was able to take my time and remember to look at the r/f Gage!(finally)
