This is just the guy in the corner with the dunce cap on.........
But, is a high temp coatings on top of the piston, any help.
Friction coatings
Gas port for sure
Would cryo help. I know it makes the piston stronger. But would it change the piston expansion as in a tighter fitting piston?
Wet sump?
Dry sump?
Oil devertes to make the oil in the cam valley only allowed to leave in the front and rear of the block.
What about tubes that directed the oil around the crank to the pan, from the cam valley.
Crank scraper...............
Friction coatings
Gas port for sure
Wet sump?
Dry sump?
