Test 5:
New VS Racing Gen2.5 7875 with the 1.25 exhaust AR and new VS Racing 50mm wastegate.
Running on spring pressure only. Has a 4 lb spring in it at the moment.
4" down pipe that dumps right before torsion bar cross member. Everything else is the same.
This is from a quick shake down test, rolling into boost in 3rd gear.
Boost PSI: 6.4
Back Pressure: -1.5 (negative)
Boost PSI: 6.4
