moparbob67
advancing the distributor is counterclockwise. expect the rpms to go up until it takes all it can , then it will misfire. set your timing, and then adjust your idle screw to get the rpm you want. make sure your mixture is where it needs to be before adjusting the curb idle.
people have different methods. i set the timing, tune the carb, set the idle
Thats what I mean the rpm goes up and my timing goes up too... way up like 30* or 40* and if I back the idle down it still reads the same.
