Well I have a bunch of skin in this game, and this is exactly the BIG question in my head. Those flow numbers look really good. I think they might even be better than the advertised numbers. I have learned recently though, that flow numbers don't always tell the full story.First of all : I have ZERO skin in this game. I like to have answers and understand them as well.
I do have one question and one only for whomever wants to answer/comment on it. Flow #'s aside and all that--Why did these heads not produce at least the equivalent of the Hughes? I mean--same cam, more lift (via accurate rockers), slight loss in static comp. How did the Eddy's do as well as they did? Seriously, I would like to know. J.Rob
I'm looking forward to the day Jim gets a hold of some BPE heads and does some testing.I'm done. I should be quiet and watch.
They were my heads sent to him to CNC. He said exactly what I'm thinking now. 560 horsepower sounds like they did did pretty darn good, regardless.I seriously doubt that Brett came here to make anyone look bad. More likely to post good information that everyone can learn from.
I asked on Mopart and got no response so I'll ask here. Did you ask Dave Hughes for a refund on his heads?
Ok well ya got me on a few things.Side by side, yup. Looks like it's a hair higher. A .200 hair. Dyno guy says the floor looks waaaybetter, and the overall shape is "whole different animal". Like I said, he really liked the. Hehasn't liked ANYTHING Mopar the 9 years I'veknown him. I dunno, maybe he's sick.....
Well I took them to my machinist/dyno guy/jedi engine master. He cc'd them more precise and they are a full 72cc.
Also, something I didn't notice, the exhaust port is raised .200 compared to the Eddy. And shaped MUCH better. My TTI'S are pretty tight. I hope things dont change down there...He was actually REALLY impressed. I mentioned maybe getting one flowed and he said don't bother. Told me there's a reason he sold both his flow benches. Pretty experienced guy. He thinks they may be the casting that Promaxx is using.
Really gave me some ****....."All this good stuff and all your time in this motor, it's about time it gets some REAL heads." "Money well spent." Geez, I had to sell one of my AR 15'S AND load a thousand rounds for the guy. He thought I was kidding...
Back to the milling, now you guys have me thinking again. Man I don't want to screw up my combustion chamber. I also cannot tear it apart again. After this upcoming dyno session, it absolutely has to go in the car.
Mill, don't mill.....mill, don't mill......
Really we are talking 1/2 point in compression. Using Summits calculator it's
11.45:1 vs. 10.96:1. Doesn't sound like much.
Looks like heads where all good then they became junk? Above quotes are from you
The reason the CR is more of a deal than just looking at a number is (and this is just my opinion) cam is wrong and it needed all the CR it could get Be real nice if we had some cylinder pressure numbers.
You have made more negative comments about me and my character/ego than I have about you I only questioned what was going on with this engine.
You have stated that my Big ego is in the way and now I am trying to make you look "Bad"
I just posted flow numbers and some air speed data and some of my thoughts on what is going on.
No personal attacks at all I can assure you.
Not all engines work out the way you think they should.
In 2011 engine masters I picked up more torque and score with a 6" piece of pipe on the collector than different cams and intakes that I tried. Close to 100 points of score and 60lbs of torque just one tiny part to this big puzzle to make Magic happen.
Well YR, I have no idea what I'm going to do next, but I am now totally against a 2.08 valve for something like this. I just think it's too damn close to the cylinder wall.Hate to be a broken record...but I've fixed a bunch of heads with blown out bowls by using the CORRECT 50* valve job. I don't like the bowl to be over 88% of valve diameter with a 45* seat. I know Chad Spier does almost 92% on some of his 23* SBC stuff and he makes it work. He does own a wet flow bench and I don't.
If your bore is doing some shrouding (which I doubt) you can notch the bore and fix most of it.
My big ***** about the 2.08 valve is you can't get the port big enough to support that valve. All it does is increase low lift flow numbers. That's almost never good in a restricted port situation.
Did the exhaust port ever get flowed? If they raised the exhaust, you may have an issue with the exhaust port being too good for the intake port.
Just thinking out loud.
My brain seems to be on idle this morning. Are you saying the intake likes to be larger than the head or the head should be larger than the intake?It was pretty good HP but the torque was really really weak (for a 4" arm) which means the cylinders were not getting filled-period. The SuperVictor is a sensitive intake that likes the port flange to be LARGER than the head port especially on the floor--I leave a .075" step/mismatch-this helps torque. Take a look at what happens to the Big Chevy guys when they use the "wrong" intake. This is why I never get too worked up over port matching--it usually isn't worth the time on lower RPM , street/strip stuff. J.Rob
could you clarify something on your last post.
You have a eng that you're going to dyno these heads on?
And a car this eng is going in after the dyno??????
Wow. That's very surprising to me. I never thought the intake port should be bigger than the head. I guess I just picture the fuel air mix crashing into the "step" on the head and pooling or something...It was pretty good HP but the torque was really really weak (for a 4" arm) which means the cylinders were not getting filled-period. The SuperVictor is a sensitive intake that likes the port flange to be LARGER than the head port especially on the floor--I leave a .075" step/mismatch-this helps torque. Take a look at what happens to the Big Chevy guys when they use the "wrong" intake. This is why I never get too worked up over port matching--it usually isn't worth the time on lower RPM , street/strip stuff. J.Rob
I thought it was strange that someone with so much dyno experience would make a blanket statement about an intake like that. There's so much that's combination dependant that you can't paint with that broad of a brush. I port matched my super victor to the victor heads as the intake was already smaller than the head. As that blanket statement indicates, I should have opened the intake up much larger. I would have liked to have been able to do extensive testing with this intake but I usually don't get R&D time on the dyno.Wow. That's very surprising to me. I never thought the intake port should be bigger than the head. I guess I just picture the fuel air mix crashing into the "step" on the head and pooling or something.
