j par
Well-hung Member
You'll have to cut some out of the front and back or possibly the side of your 4-speed floor hump to make it fit. If I'm not mistaken a little bit of the Cross frame as well...
the idea is once you make the mount then you know the straight distance between the two throws. You put the lock pin in the vertigate and put the ears in neutral and then you know how long you have to make you're all thread between your hem joints..Yes I do. But I want to secure the shift linkage before I make the mount.
Dose the ramrod work exactly like the vertigate?Yup That may be the route I'll end up having to go. Or I have a Hurst Ram rod shifter I may use.
More or less, it works off the same principal. here is the link to the one I have.Dose the ramrod work exactly like the vertigate?
I’ll have to crawl under the car and look to be sure, but I believe I turned my reverse lever around and upside down and it now goes over the crossmember. I think I remember trimming the floor pan just a wee bit to make it fit this way but now it’s tucked up out of the way.I think you'll need the plate and a couple standoffs for between the plate and shifter mechanism, along with the shifter levers.
My 1-2, 3-4 are basically two straights with 3/8"-24 threads (I believe) and pivots at the shifter. The reverse runs under the trans crossmember. I'm not keen on it but that's the way it came and it works.
Some pictures I dug up.....
Thanks! I'll have to look at that. It does get pretty tight in there....I think I remember trimming the floor pan just a wee bit to make it fit this way but now it’s tucked up out of the way.
Yup, now that you say that I did have to turn the reverse lever upside down as well as switch my first second - 3rd 4th shifter ears...I’ll have to crawl under the car and look to be sure, but I believe I turned my reverse lever around and upside down and it now goes over the crossmember. I think I remember trimming the floor pan just a wee bit to make it fit this way but now it’s tucked up out of the way.
If you do have a original, I'd be interested in it. Trade in on the Hurst Ram Rod?I think I might have the mounting bracket
Any dimensions on this? I may Fab up my ownView attachment 1715357359 View attachment 1715357360 First a small plate to locate where the shifter will go. It looked like you have a spray painted template?
Well then have patience Grasshopper when you get the transmission bolt the shifter up and measure...I'm building a car around a Verti gate, As such, I don't own a 4 speed. Hence I can't build the rods?
I keep forgetting this post when I'm in the garage...Any dimensions on this? I may Fab up my own
Also you can connect the transmission crossmember on to the bottom of the transmission to make sure you're going to clear that with your reverse rod and the forward gears are just straight rods..I'm building a car around a Verti gate, As such, I don't own a 4 speed. Hence I can't build the rods?
