Short block no timing chain on yet either
Ok. I was thinkin long block somehow.
So if its a 3.58 stroke then it should be around .003?
So then would i need to get undersize bearings or possible polish crank?Your thinking stroke. Think journal. 2.5 inch diameter = .0025 clearance.
Hmmm ok ill look for someYou would with .001 oversize I would think.
Any idea where i could get those? Cant find em on summit only undersizeYou would want .001 oversize I would think.
Well i would like to use clevite but ill use king if i need to, to be honest im still not seeing it lolNeed your brand and part number to check it out.
But King says this about there chevy bearings.
Notes
These bearings are available in the traditional Std, .010, .020 and .030 specs.
In addition, they are also available in the X.001 and .001
The X001 bearing is used when 0.001" of additional crank clearance is required.
The 001 bearing is used when the clearance is needed to be tightened up by the one additional 0.001" of reduced clearance.
Some parts are not legal for use in California or other states with similar laws/regulations
Im not sure on that, and ill double check part number but i believe they are clevite ms-540p ill double check. Those are the main bearing part number it all came in my scat kit amd im hoping i didnt toss the boxAlso doesn't your crank need a radiused bearing.
It says both help oil clearances by .001The mains are the right part number but are not saying they are +.001 in their description. Might want to check that.
Alright cool ill make the purchase then, ill have to redo rear main seal also since im doing mains alsoThat should give you what you need.
25-28 ft lbsWhat is your clearance?
How much torque to turn it over now?
That was actually a question i was going to ask so now i know thank you. I was leaning towards the xe274 myself but hope i wont have to change springs or anything. With the xe268 i was worried about to much pressure so i feel the xe274 or the lunati would solve that. I do like the xe274 amd the lunati i just want best bang out of this engine. I will be cruising but will probably be doing some agressive cruising with some track timeYou know to run the hardened intermediate shaft with that high volume pump?
As for your cams I like the xe274h. Just my choice of the three you have. If you want to race more often than cruising I'd use the voodoo.
