MoparMark91
I was also looking at the comp nostalgic purple cam but going to have to decide between the 3 soon hmmm decisions decisions
Just checked it out i feel my main issue is going to be that cylinder pressure and choosing the right cam to help with that. The info there is good though thanks
Alright guys im stuck right now its a toss up between 3 cams
XE274-own
Lunati704-own
Lunati703-can get with summit bucks
I already disregarded my XE268
90% street 10%track
I didnt assemble the short block without the cam. I had the XE268 in and decided against it. I dont want to spend more money on the cam, i have summit bucks to buy 1 more cam if i dont want to run the other 2 as i stated above. Ive considered a custom grind but dont want to spend more money out of pocket at this time so im working with what im dealt with like i stated above. I havent degreed any cam yet as you can see.Why not call Jim at Racer Brown and have him grind up something custom???
It can't be money because it's about the same price.
BTW, why did you assemble the short block WITHOUT the cam??? It makes it much tougher to degree the cam. You are going to degree the cam aren't you???
Just realized something guys, i bought the durabond engine hardware kit it comes with the woodruff keys for crank and cam. Does this look right for the crankshaft and key? the gap? It is a scat crank
XE275HL, ill post why after im done setting up my sons bdayso which cam and why?
Well i feel the lift will work perfect with my eddy heads especially if i do a light port job.Oooh, nice! I've got one of them and a set of lifters sitting on the bench waiting for the snow to fly. Hoping that will make good match with ProMaxx 171 heads, RPM AG, and 650 AVS2. Will be very interested in your reasoning and results.
Well i am inly eunning 1.5 rockers so i thini itll be alright? Why have you ran the HL before?Let's see how the HL works for you
btw
the difference between 274 and 275 HL is more than
274 to 274 with 1.6 rockers
some have and some have with magnums whichhave the 1.6 stock
I just commented because some think that 1.6 rockers make as much difference than a cam ground on the Mopar size lifter like the two voodoo's and your HL cam
They do not make as much difference
which motor gzig5?
b3 kit with shaft and roller rockers?
or?
what springs
what headwork for clearance was required
following readers will need to know
