If all 8 cylinders are at least .034 run it.
1008 = .039"Yeah so maybe i will be alright with what i have i just have read more clearance is recommended before. These are icon 741 forged pistons so leaning toward i think ill he okay as long as that gasket didmt compress more due to the head studs or anything lol
I just dont want to cut it too close with the clearance
The blue permatorque are .050? I always heard thr compressed same as 1008 .039
So you got a point there rusty, so i did think about cometic but...my ra i didnt believe would be good enough on the surface, and ive ran felpro before and no problems, along with others that sware by them. My block did get machined but i dont think it would if bern suffice for the gaskets, this is my first performance build so i figured felpro has done me goid in the past why not slap em on, plus i have to slow down and wanted to budget somethings cause i still need a new rear end lol......also the wife came across my receipt stack for my build .Now, I'm just askin here, so don't take this the wrong way, scooter........but you have some really nice parts and some beautiful machine work goin on there. "Loonimum heads" as an old friend of mine used to call um, lol, really nice pistons, lots of dollars elsewhere, so I gotta ask, why are you running run of the mill head gaskets? No way in hell itself would I do that. I'd be callin Cometic, or even lookin at a nice copper gasket. I got nothin against FelPro, they make good stuff, but you're building better than "good". jmo.
D'OH!
Honestly wish i could run em withoutout worrying about the ra
Don't... what you have works and is reliable. Raced and raced and raced on standard head gaskets. Good flat surfaces are more important IMHO.Damn it now u got me thinking lol
The only attribute I can think of for Cometics is their resitsance to blowing out, and some good variability in setting thickness and hole size. But your SCR/DCR is set fine as it; tune it right and be happy.
BTW, the damper looks good. If it seated firmly when installing, and you got the 135 ft-lbs of torque on the snout bolt, then it sounds all right.
I appreciate a lot i do, i nust have thoight about the cometic for the exact reason of being able to tweak the quench even better and have always wanted to try cometic honestly. In the picture it looks pretty good im trying to compare it too my picture of my block since im not next to it. I zoomed in on the surface of my block and i can see very fine lines but just curious if it would seal up. I am also running arp head studs,Maybe ill stop by my machinist and talk to him about if he mills it to a certain grit or something?I can tell you that we have a set of Cometics sealing fine so far on a 340 with Edelbrocks with no particularly spec'd surfacing work on either head or block. Heads new as surfaced from Edelbrock, and block surfaced to be very flat at a local shop. But not a ton of miles on the engine. ARP head bolts, not studs. Carefully torqued down in steps. Heads off and back on once wiht the same Cometics. I only went to Cometics to tweak the quench/squish gap.
Attached is the best pix I have of that block's surfacing work; Maybe YR can look and comment on how smooth this surface is.
I never have asked what particular surface my local shop puts on here in VA; the owner has built lots and lots of race engines (8's, 6's and 4's) for the local track, so they may just know how to put on a (finer?) finish. IDK. I've had machine work done one my rally engines are about 4 different shops in VA, IN, and OH over the years, and never had a head gasket issue except 1, and rally cars see a lot of heat cycles (but probably not the same peak power levels in terms of HP per ci). The head was warped in that 1 case. Otherwise, all standard kit gaskets, Permatorques and composition types, even with 14-15 psi boost..... no issues as long as the parts are good and flat.
And yes the bolts/studs have to stretch a miniscule amount to take the pressure on each cylinder firing. But IMHO it is a matter of degree. If they stretch .00001", then probably not any issue. We're not running top fueler engines here. At what HP level, this become more of an issue is something I don't know the answer to.
Yes I always re-torque regardless on anything even semi-performance.If you go the felpro, I would retorque them.
Of course they will LOL! BTW I think you meant to say 'They are NOT leaking yet.'......I'm all for mirror finish. My heads and block were damn near mirror finish and I used Fel-Por gaskets. They are leaking yet. I'm sure when I get home tomorrow they will be puking coolant right on the floor now that I typed typed that (thankfully it's Evans coolant so that's only 40 bucks plus shipping a gallon).
I've also finished and ton of surfaces with a stone. And none of those ever lost a Cometic. One was a 300 inch blown gas Comp Eliminator engine. 10:71 blower on gas. He was shifting at 9400 and crossing at 10,200. I know because I've seen downloads from 100 of his runs. Ex Pro Stock guy. Probably the best natural driver I've ever seen.
BTW, what is you objective in using the Evan's coolant?
OK, thanks. I've yet to go down that road... if I ever will.
FWIW, it actually has lower heat conduction than a standard AF-water mix so will run a bit hotter. But the fact that it has a much higher boiling point is probably of value in keeping the chambers a tad cooler when you push things hard.
