I don't know its all inside now why?
Cuz I need one like it.
Luckily I found a pix of it post 1299Cuz I need one like it.
I am it was a very unique experience. I was a nervous wreck to be honest my wife kept telling me just calm down and take a break lol its an experience im glad to have had but don't want to do it again. HahaLooks good, I'm betting that you are very relieved to have that part done, a couple scratches are minor given what you had to deal with just getting it in.
Yea I got another busy day tomorrow. Tomorrow im gonna torque everything down work on the exhaust manifolds, down pipe, get the new pipe welded to the existing tailpipes, radiator buttoned in engine accessories on. Maybe even put the fenders on. I gotta go ahead and raise the torsion bar adjustments up now that there is weight on the car, even on ramps im having a horrible time getting under it lolDang buddy good work, get yourself some sleep.
No not yet i just slightly tightened it down i have the longer one in the middle the shorter one that goes closest to the head is missing i thought I could make it work without it but nope lolMaking good progress, looks great! Did you find a spacer for the alternator bolt yet? I might have one around if you can't find it.
Yea I don't get it at all i thought maybe I didn't have the correct lever so I looked it up to buy the correct one and I have the right one. I don't understand why it's not lining up. There is an obvious angle behind the bracket and lever that is not supposed to be there I have tried shiming it nothing has helped I downloaded the instructions and followed them to a T still not lining up. I'm wondering if somehow through the years and moves the bracket got bent. I don't see any obvious bends or anything. I'm gonna try it again tomorrow. I gotta finish up the trans lines too. I think that and the fuel lines and im done under the hood. I still have to hook up the wiring in the cluster and im ready for break in!Sorry I can't be any help with the shifter, never used one myself, mine has a B&M installed by a po.
post 83. don't know if this helps, you didn't post any pics of how it all lines up, but on mine i modified the KD lever to get it in a different plane of movement. ended up cutting the arm off the lever and welding back on the top side of the bracket...I'm having the awfulliest time with the stupid shifter linkage on my Hurst shifter. ..And it won't go on the top of the lever which its supposed to without interfering with the kickdown lever.
Yea thank you that would be helpful.I can measure the length of the spacers on my Duster if you need the measurements.
